March 16, 2026, 05:38:00 AM *
Author Topic: I/S temp lights came on today (Solved)  (Read 1612 times)
larue
Clermont,FL
« on: December 09, 2015, 11:26:56 AM »
after an hour run on the new to me interstate 20k on the clock, temp light came on at a stop and went out in less than 30 min, next stop did it again and out after may be 20 sec and no fan came on, rode home about 40 min and parked it running to see if the fan will come on instead the dreaded light showed up again I shut off the bike only to hear this loud sound like bad bowel movement  and suddenly one of the 3 breather tubes under the bikes belly spitted out a pool of 1/4 gollon of slightly yellowish  water, grumpy adviced to check the fuses which checked out ok, then suggested to unplug the fan switch and ground the wire if fan runs the switch is bad, if it doesn't its a possible bad fan motor or wiring problems. haven't done that yet as it required removing the left rad pod. by the way over flow bottle full. any thoughts are appreciated. thank you
« Last Edit: December 16, 2015, 02:17:16 PM by larue » Logged
Tropic traveler
Silver Springs, Florida
« Reply #1 on: December 09, 2015, 01:27:54 PM »
Grumpy's diag sounds spot on {as usual}.
Antifreeze is supposed to be neon greenish not yellow. I would say a complete flush & fresh Honda brand antifreeze is in order too.  Wink
'13 F6B red for Kim
Grumpy
Tampa, Fl
« Reply #2 on: December 09, 2015, 03:22:42 PM »
Overflow bottle being full is normal when the bike gets hot. When it cools it should be drawn back into the radiator.
larue
Clermont,FL
« Reply #3 on: December 10, 2015, 09:08:18 AM »
Over flow bottle still at max, grounded the fan switch , no response , took out the radiator and ordered a fan assembly
Bronxboy
Tampa Bay FL
« Reply #4 on: December 10, 2015, 10:01:42 AM »
Great being able to trouble shoot a problem in a couple of post's, This is a Great Forum !! cooldude
Grumpy
Tampa, Fl
« Reply #5 on: December 10, 2015, 10:39:46 AM »
Might be wise to connect the fan direct to a battery and see if it works, would rule out a broken wire some where.
« Reply #6 on: December 10, 2015, 11:45:15 AM »
Hope you didn't pay more than $155 for it. That's from Procaliber.com with free shipping.
Bert AKA,Valkaholic
Back-N-Black
« Reply #7 on: December 15, 2015, 08:20:16 AM »
If I Had Known That You Needed A Fan Motor I Would Have Offered My Spare At A Fraction Of The Cost Of A New One .
larue
Clermont,FL
« Reply #8 on: December 15, 2015, 04:32:59 PM »
price on ebay  was not bad 28 for a complete fan shipped already here and getting ready to put it on tomorrow with the help of Jack.
I am just surprised this could happen t a low mileage bike, may be the fact it sat for a 3 year is a factor???
larue
Clermont,FL
« Reply #9 on: December 16, 2015, 02:26:39 PM »
Shout out to jack for helping coming over and help install  the radiator, fan motor was the culprit, was toast, fan from ebay with 28 dollars shipped, bolted right on, and grounded with the fan switch ad wala its spinning, we filled up the rad, run it for a while thermostat kicked in, added a bit more coolant, a bit later fan kicked and off for lunch  and we had a nice chat over lunch at Clermont buffalo wings, then rode the Clermont hills for an hour or so and back. thank you also for the gift jack. thanks to all those that help with the diagnosis. blessed to be surrounded by this great group of people.
Grumpy
Tampa, Fl
« Reply #10 on: December 16, 2015, 03:51:10 PM »
Cool, glad you got off cheap on the fan.  cooldude
Thunderbolt
Worthington Springs FL.
« Reply #11 on: December 16, 2015, 04:15:49 PM »
Good deal Larue.  If Grumpy gets too covered up with work he can send the overflow to you. Cheesy
Flrider
Jack
Kissimmee FL
« Reply #12 on: December 16, 2015, 06:27:27 PM »
You are welcome brother, I'm just paying it forward, I have gotten lots of help from this group as well.
Glad your ride is back up and running  cooldude
Nice ride on those Clermont hills, they never get old and they are the next best thing after the Brooksville roads.
FYI everyone, Larue had most of the job done by the time I got there so pretty soon he will be able to take on jobs just like Terry said  Grin Evil
