February 11, 2026, 09:56:27 AM *
Author Topic: 2000 Tourer carb float springs  (Read 873 times)
medulla762
« on: December 12, 2015, 03:59:46 PM »
What is the correct force for the carb float seal spring? When ordering new seals, do they come with springs?I notice there are several different forces for new springs. I don't see the spring on the fiche. I'm I not looking hard enough? 2000 Tourer
hukmut
Stone County, Mississippi
« Reply #1 on: December 12, 2015, 06:21:48 PM »
Different force? Are you not buying OEM? ??? Where are you looking?
Ride safe.
sixlow
St. Augustine, Fl.
« Reply #2 on: December 13, 2015, 05:15:46 AM »
I think the float spring is in the float valve, and not replaceable, it's a very small plunger on top of the tiny lil float valve, there are several different vendors but stock is a Keihin 18-8955 best price is on amazon, $5 less than the jets r us price. this video may be helpful.
I have just been doing my homework because I am about to do my first carb job. These video's don't represent the amount of parts you get from "Redeye" kit because he doesn't separate the carbs.
https://www.youtube.com/watch?v=7rtNABYbpmk
Steel cowboy
Spring Hill, Fl.
« Reply #3 on: December 14, 2015, 03:53:57 PM »
That's my project too Sixlow. I'm popping the bike up on the table Chirsrmas eve and I have that whole week, after, to do the carb's and desmog too. I got the red eye carb hose and Orings kit plus new float valves. I picked up the "shiny desmog kit" to install. I'm going to put the pods on too. I got the crash bar, the plastic radiator shield and all the nuts and bolts ready. It's going to be a fun week for me. The web site you mentioned is where I've been going to, to get acquainted with the procedure.
2001 black interstate
2003 Jupiter Orange wing
Bagger John - #3785
« Reply #4 on: December 15, 2015, 08:23:02 AM »
I think there's a difference between the Std/Tourer and I/S radiators where the grill mounting hardware is concerned.
Compare Find #3, 19 and 20 shown here:
http://www.hondaeasttoledo.net/OEMpartfinder.htm#/Honda/GL1500C_AC_%2800%29_MOTORCYCLE%2c_USA%2c_VIN%23_1HFSC341-YA300001/RADIATOR/GL1500C-00-AC/2Y14MZ0VE1AMZ04F3200B
With Find #2, 23 and 24 here:
http://www.hondaeasttoledo.net/OEMpartfinder.htm#/Honda/GL1500CF_A_%2800%29_MOTORCYCLE%2c_USA%2c_VIN%23_1HFSC410-YA100001/RADIATOR/GL1500CF-00-A/2Y14MBYXE1AMBY4F3300AA
At a minimum you'll need the I/S grill mounting brackets - and may need an I/S radiator to boot IF the top bracket mounting bosses are absent on the Std/Tourer radiator.
Perhaps other members can chime in on this. I'm going to add pods to mine next spring and bought a complete, used I/S radiator - including required brackets.
Steel cowboy
Spring Hill, Fl.
« Reply #5 on: December 15, 2015, 07:22:14 PM »
John I do have the I/S radiator brackets (4 of them) and the longer buzz bolt too. I just didn't mention it. I'm aware that the chrome side radiator covers will have to be removed but I believe the top radiator cover can stay. The bike is a 2001 interstate the P/O did not like the look of the pods so he removed them. I don't believe the radiator is different.
« Last Edit: December 15, 2015, 07:27:38 PM by Steel cowboy » Logged
« Reply #6 on: December 16, 2015, 05:52:14 AM »
http://timskelton.com/valkyrie/how_to/pods.htm
Bagger John - #3785
« Reply #7 on: December 16, 2015, 05:54:43 AM »
Ahhh...you're good to go at that point. It's a little harder when adding pods to the other two models!
