TomT
Our very first day on the Valk up on the BRP!
Lynchburg, Virginia
« on: September 11, 2009, 08:52:52 PM » |
I noticed that my headlight's aim is to high. How do you adjust the aim on it? Thanks in advance, Tom T Lynchburg, VA
PAVALKER
Pittsburgh, Pa
« Reply #1 on: September 11, 2009, 08:58:03 PM » |
IS there a pivot point where it mounts?
I assume it is the bike in your avatar pic.
John
TomT
Lynchburg, Virginia
« Reply #2 on: September 11, 2009, 09:02:41 PM » |
I was looking for a pivot point, but didn't see one. Yes, it is the Red and White Valk. I'm thinking there might be screws like on a cars headlight for adjusting up and down, but not sure. Thanks, Tom
« Reply #4 on: September 11, 2009, 10:57:49 PM » |
Looking at the headlight from the front, there are two holes to insert a screwdriver at approx 4:30 and 7:30 positions. Insert a phillips screwdriver in the 7:30 hole. Clockwise raises it, & vice-versa. I find it's helpful to put a sheet of cardboard standing in front of the headlight so I can see what I'm doing to the beam. Then take it for a spin to see the effect. I've found that when I change the bulb, the beam usually needs adjustment as the filiment is in a slightly different position. Sometimes I'll just throw a screwdriver and a flashlight in the luggage and go set it on the side of the road. I set mine by where it puts the high beam.
TomT
Lynchburg, Virginia
« Reply #5 on: September 12, 2009, 07:22:34 AM » |
Good morning, Thanks guys!  I'm going to go out and work on it this morning. Got the lawn mowed yesterday, and Joanne sleeping today. So today, I get to play!!! Thanks again, Tom
Big Rig
« Reply #6 on: September 12, 2009, 09:07:44 PM » |
I did mine when I had the speaker cover off on the fairing....
I have been having an on going problem with my left blinker loosening...
Madmike
« Reply #7 on: September 13, 2009, 09:00:50 PM » |
« Reply #8 on: September 14, 2009, 06:41:55 AM » |
Alrightie then........remove the trim ring ......
Not necessary, follow MarkT's advice for locating the adjusting screws and the post telling how/where to aim it. I was looking for that myself but MadMike beat me to it. I've used that same procedure often, keep in mind when traveling with a load in back your light will be higher. If your riding is two-up a good share of the time you might want to use a happy medium on the elevation.
Earl in Pensacola
« Reply #9 on: September 14, 2009, 07:22:41 AM » |
I never thought about this as another benefit of having #416 air shocks, but I just add or reduce the shock psi a lb or two to adjust the headlight. Really!!
TomT
Lynchburg, Virginia
« Reply #10 on: September 14, 2009, 02:30:21 PM » |
Got R Done gents! Thanks for the advice!
redflash
« Reply #11 on: June 16, 2010, 05:31:36 PM » |
Good link Mike, the one I googled said the same thing, but 25 ft instead of 17 ft. I'll go for a spin and see how it worked. I had mine off when I did the steering head bearings at 64,000 and it's needed a tweak since.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #12 on: June 17, 2010, 03:16:27 AM » |
(1). Find a flat patch of ground with a white or light-colored wall at one end. Place the bike 25 feet from the wall or garage door (2). Measure from the center of the headlight to the ground with the bike level (3). Now go over to the garage door and mark one line at the same height above ground, and another two inches lower (4). Use a carpenter's level to draw a horizontal reference line (or masking tape) (5). Switch on the headlights and mount the motorcycle. The low beam's upper cutoff point should rest right on the lower line (6). Because most bikes have combined high- and low-beam reflectors, setting the height (and checking to see that the beam is centered along the bike's long axis) is about all there is to it. But if you have separate high beams, make the center of the high beam land on the upper line.
