February 11, 2026, 09:56:06 AM *
Author Topic: Is This Plug and Play?  (Read 1593 times)
« on: December 16, 2015, 07:03:45 AM »
http://www.ebay.com/itm/252187787463
Bikes are in storage or I'd look.  Does this two prong adapter clip right in to the Valk's accessory plug as advertised, and if so would it power on and off from the ignition?  Can I find just the 2 post plastic adapter alone?  I'm thinking about setting up a GPS to be charged from the accessory plug.  Thanks.
« Last Edit: December 16, 2015, 07:05:54 AM by Valkorado » Logged
Roidfingers
Tuscaloosa, Alabama
« Reply #1 on: December 16, 2015, 07:16:36 AM »
I have a 98 std. and the acc. connection on mine is a bullet female connection
Roidfingers
Tuscaloosa, Alabama
« Reply #2 on: December 16, 2015, 07:27:08 AM »
Also on mine it has two connectors in the rubber shield. One goes just to the switch.  I bought one of these that goes straight to battery. If nothings plugged in then it uses no power.
http://www.amazon.com/gp/product/B00RF3AW76?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
Also have one of these which is very nice.
http://www.amazon.com/gp/product/B000XY5184?psc=1&redirect=true&ref_=oh_aui_detailpage_o09_s00
And run all my acc through this
http://www.easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/pc-8.html
this way along with my Smartswitch, I have hardly any power going through my starter switch. Which they say if you run everything through your switch it could burn up.
« Reply #3 on: December 16, 2015, 03:35:14 PM »
Thanks for the info.
Lyle Laun
Calgary, Ab
« Reply #4 on: December 16, 2015, 04:44:41 PM »
I've got bullet plugs on my accessory wire. Don't think that end will plug n play, probably have to just cut off that connection.
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
Paladin528
« Reply #5 on: December 17, 2015, 11:15:59 AM »
if you cut the connector off and crimp on 3.5mm bullet connectors then it will work just fine.
I use my accessory connectors as a trigger for my relay junction box. Works like a charm
