March 15, 2026, 03:21:52 AM *
Author Topic: Powerlet installed  (Read 2933 times)
bradrcfii
« on: December 24, 2015, 09:42:00 AM »
Water proof power plug connected directly to the battery.  Includes adapters for USB, cigarette and SAE for battery tender.
« Last Edit: December 24, 2015, 06:56:33 PM by bradrcfii » Logged
dans2014
« Reply #1 on: December 24, 2015, 09:52:47 AM »
 Shocked Very nice
Dan's 2014 Valkyrie
TallRider
Cape Coral, Fla
« Reply #2 on: December 24, 2015, 04:16:50 PM »
Careful the USB is a 5 v outlet power drain all the time. Will run your battery down if left sitting to long. If you keep it on bat tender should be no problem. I have one and pull the fuse when not using it. Will rewire through switch when
I get to it. Drained my batt in 5 days wouldn't start.
1951 HD FLH Chopped
1978 Honda Goldwing
2005 VTX 1800
2014 Honda Valkyrie
bscrive
Ottawa, Ontario
« Reply #3 on: December 24, 2015, 04:24:14 PM »
Yep, I had this happen on my old valk.  Battery drained down so much the lights barely came on.  Learned my lesson there.  Next time it goes on a switched power wire.
The wires for the fog lights are right there.  Hook it to that.
bradrcfii
« Reply #4 on: December 24, 2015, 06:17:35 PM »
Could I power an iPhone while the bike is running?
« Last Edit: December 25, 2015, 05:53:46 AM by bradrcfii » Logged
« Reply #5 on: December 25, 2015, 05:55:40 AM »
I will install a usb port on my bike really don't need the lighter adapter but that is a nice installation.
bscrive
Ottawa, Ontario
« Reply #6 on: December 25, 2015, 09:32:32 AM »
Of course, but you don't need that expensive usb adapter.  Go to eBay, and buy one there.  It will only be @ $4, and you will probably be able to get the same one.
