January 29, 2026, 06:18:33 PM *
Author Topic: too late to start using synthetic oil?????  (Read 2090 times)
waterboybpf
Albertville, AL
« on: September 12, 2009, 09:34:36 PM »
i've read on other forums about folks switching to synthetic on a bike with a lot of miles and having trouble with leaking.  anybody heard of this with the valks?   my '99 has 42k miles on it.  would i be best to stick with dino-oil?
paul
roboto65
Conroe,TX
« Reply #1 on: September 12, 2009, 09:39:34 PM »
A Valk that leaks oil the horror  Shocked Shocked I have heard tale but never seen it  2funny 2funny
You should have no problems with the switch does wonders!!!
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
« Reply #2 on: September 12, 2009, 10:02:20 PM »
Go for it. It'll shift better and run cooler and quieter.
« Reply #3 on: September 13, 2009, 06:03:24 AM »
I've 143,000 on mine and use nothing but synthetic.
« Reply #4 on: September 13, 2009, 06:06:49 AM »
Go for it!  I switched around 30k and have never looked back.  I switched at 25k on my Yamaha V-Star 1100 and the clutch started slipping.  I replaced the clutch and all is well.  Don't worry about the clutch with the Valk, it is much more bike that my Yam.
Hay  Cool
« Reply #5 on: September 13, 2009, 06:46:23 AM »
242,000 + change on MGM.
Have used Mobil1 for autos since 58,000 + change miles.
I see no reason not to go full synthetic oil.
It will run cooler, quieter & not leak oil, unless you have a hard seal.
If so, it will leak with any type oil ya have in it. Evil cooldude
« Reply #6 on: September 13, 2009, 06:48:43 AM »
Hey fellow Jarhead, what is the deal with the little red 'x' in some of our weather banners?  My Vegas one in particular.
Or should I head that off to Scottie?
« Reply #7 on: September 13, 2009, 06:52:04 AM »
Hay R J, looks like it is working again.  Don't know what the problem was, but it is working now.  6:49 a.m. Local time temp is 70 Deg F.
Hay  Cool
Tropic traveler
Silver Springs, Florida
« Reply #8 on: September 13, 2009, 06:37:24 PM »
Dino oil from 0-60,000 miles.
Rotella 5w40 full synthetic from 60,000 to present 94,000 miles.
No runs, no drips, no errors!  cooldude
'13 F6B red for Kim
« Reply #9 on: September 14, 2009, 03:16:35 AM »
Paul, that warning was mostly applicable to older Harleys, which were inclined to leak oil anyway.  The argument was that synthetic would compromise the older gaskets (like at the rear (hotter) jug to crankcase junction).  Forgetaboutit for the Valk, it is not an issue
waterboybpf
Albertville, AL
« Reply #10 on: September 14, 2009, 07:44:06 AM »
thanx everyone, i may go ahead with it, then.
