February 11, 2026, 09:56:26 AM *
Author Topic: How many vacuum lines are you using on your cruise control?  (Read 1547 times)
« on: December 31, 2015, 12:58:30 PM »
I'm getting ready to pull the tank and airbox, need to replace my inline fuel filter and check the vacuum hoses used for my CC. I have all the available vacuum ports used and want to get rid of most, they all feed into Tees and a single line from each bank to the reservoir. I'm wondering why I can't just use possibly two hoses, one from each bank and feed into the reservoir. Seems that should give me plenty of vacuum to operate with. I'm open to any suggestions.  cooldude
It's the Audio Vox system and has been trouble free for close to 10 years. But recently on a day run I noticed if I hit the ACCEL button the engine would appear to die a bit, then suddenly WHAM, the cruise would catch. Not a pleasant feeling....or sound, so want to clean it up and bit and see if it's possibly a leak somewhere. There's a one-way valve in each line so there could be a vacuum leak and it would still run fine.
« Reply #1 on: December 31, 2015, 01:10:04 PM »
My next project is redesigning the fuel path.  It's going to be more complex than I would like but I want to be able to have the Dan-Marc, fuel filter, T-fitting for the belly tank and still have easy connection to the petcock while keeping the whole line on a downhill.  It will involve some S-turns in the path using copper tube fittings, probably flare or sweated. Won't work on it until the second half of Jan.
BonS
Blue Springs, MO
« Reply #2 on: December 31, 2015, 05:30:51 PM »
I have three vacuum hoses, each with a check valve, teeing into one another. I don't have a reservoir. It has worked under all conditions and never failed. If you use check valves be sure to "check" them with your mouth to be sure they're working. I had one out of four that I bought at an auto parts store that wouldn't check. It's a simpler design and helps to get rid of "stuff".
« Reply #3 on: December 31, 2015, 07:03:28 PM »
Bon, all my lines have a check valve in them, each line comes off the vac. at the back of the carb intake. I'd just like to get rid of all but two lines/hoses, my reservoir has two inputs, one from each side. If you can get by with just three and no reservoir, I surely should be able to operate with just two with a reservoir. Figure if I use one from each side it should work fine.
Dusty
Mill Bay B.C.
« Reply #4 on: December 31, 2015, 07:39:07 PM »
 I had issues with mine not engaging all the time. I tracked it down to the solenoid valves inside the actuator were sticking. This link is what I used to fix mine. Let me know if you need more info. I use 5 lines to a canister.
Dusty
http://www.vulcanbagger.com/forums/showthread.php?t=19536
« Last Edit: December 31, 2015, 07:42:36 PM by Dusty » Logged
« Reply #5 on: December 31, 2015, 09:19:31 PM »
Dusty, great write-up, I'll keep it in mind if I don't find any other source for the hesitation.  cooldude
Kye
Brisbane, Australia
« Reply #6 on: January 01, 2016, 02:46:54 AM »
I've just done an install the same as Bon, three vacuums, all from the same bank, all with check valves (we can't get the ones you US guys use in here Australia so I had to use check valves designes for a fish aquarium - not sure how long they're gonna last), and no canister, and it worked flawlessly. The worst variation I observed when going over a hill or up a dip was about 5km/h.
I'd speculate that two lines used in conjunction with a canister would work equally well.
1997 Valkyrie Tourer. Green and Cream.
« Reply #7 on: January 01, 2016, 03:17:25 PM »
I looked over the write up of the audiovox, and the home build vacuum reservoir. Uses 5 lines.
I would think if you wish to only use 2 vacuum lines instead, you would need to reduce the size of the bottle. 2/5th of the lines, so reduce the bottle to 2/5th of the size.
http://www.valkyrieriders.com/shoptalk/Cruise-Control.htm
I  found someone advertising 2 of the Audiovox for sale.
« Last Edit: January 01, 2016, 03:32:37 PM by gordonv » Logged
Daniel Meyer
The State of confusion.
« Reply #8 on: January 01, 2016, 04:24:29 PM »
I use three ports. Check your check valves. Put one in each line AND one after they all t together to go to the reservoir. The reason? They do fail. The valk is as hard on them as it is vacuum lines (substantial back pulse). They are easy to check though...if ya don't mind sucking on your bike Smiley
CUAgain,
Daniel Meyer
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #9 on: January 01, 2016, 04:47:04 PM »
John,
I use the MC Cruise Control and had several issues back in 2014. I contacted the company and they stated it was from the ethanol in our gasoline and it now requires a seasonal cleaning of the vacuum actuator chamber with a denatured alcohol.  The servo setup look very similar to mine.  I can email you the tech guide to cleaning servo if interested.
PM me with email and I will be happy to send.
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
« Reply #10 on: January 01, 2016, 04:55:15 PM »
At present, I have #2 & #4 feeding from the left side and all three from the right side, each with a check valve.  My #6 is capped off since I have a manual petcock. I think I'd be safe in using just one from each side, capping off the rest. Since the left side already is using two, I might replace the hoses and valves and keep those, then add just one from the right side, again with new hose and check valve. That would cut down on the the amount of hoses susceptible to breaking down and leaking. In the years the system has been installed(about ten) it appears the bead chain has stretched a bit so considering replacing it with new or similar. By the time it all breaks down and needs going over again, I'll most likely no longer be riding since that would put me in the mid-late 80's.
Been so long since I had the tank and airbox off I had forgot what a PITA removing the airbox is. I need to relocate some extra wires I've run since the last time it was off.
live2ride
Coral Springs, FL, USA
« Reply #11 on: January 05, 2016, 11:12:11 AM »
I am using 4 vacuum lines with the Audiovox and no reservoir. Never had an issue. Our machines have plenty of continuous vacuum.
People don't plan to fail, they fail to plan.
« Reply #12 on: January 05, 2016, 02:07:19 PM »
I ended up using two lines from the left and one from the right, all with check valves and feeding into a reservoir. I replaced all the hoses and check valves, capped off the remaining vacuum ports. Then reduced the slack in the bead chain that's hooked to the carb linkage. Next I replaced the fuel lines from the petcock to the tee, installed a new inline filter, the airbox is back in so just need to hook up the tank and should be done.
Garland
#618
Hendersonville NC
« Reply #13 on: January 08, 2016, 02:09:30 PM »
I have a McCruise, and am using one vacuum hose with check valve.
« Reply #14 on: January 08, 2016, 02:29:47 PM »
Does your cruise control tend to act slowly? I.e. when you push the set button, does it take a while for the cruise to take over from your hand holding the throttle?
MarcusS
New To Me August 2013
North Houston
« Reply #15 on: January 12, 2016, 05:21:03 PM »
None, My Rostra system is all electric.
Life goes on whether you are in it for the ride or not.
