February 11, 2026, 09:56:52 AM *
Author Topic: Chrome Fuel Gauge  (Read 1057 times)
« on: January 09, 2016, 08:27:54 AM »
Has anyone installed one of these on their Valk?
http://www.ebay.com/itm/172056217801?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D172056217801%26_rdc%3D1
Nice looking but not cheap.  You'd have to mortgage the ranch to get the 3 gauge setup shown in the third picture.
sdv003
Prescott Valley, AZ
« Reply #1 on: January 09, 2016, 09:23:50 AM »
Try Motosens.de.  They have one that looks just as nice.  Somewhat expensive, but not crazy like that one on ebay.  they make good stuff, I have a couple of their gauges and I like them.
big poppa pump
San Antonio, TX
« Reply #2 on: January 09, 2016, 09:30:47 AM »
Wondering if adding the pressure sensor to the fuel line will restrict the fuel flow rate?
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
WintrSol
Florissant, MO
« Reply #3 on: January 09, 2016, 11:07:28 AM »
Also, remaining fuel would be little better than a guess, as the fuel height determines the pressure, but the tank shape controls the volume at a given height. The rate of drop would start out slow, then get faster as the tank empties. Unless you calibrated it by adding a small amount, making a mark, repeat, until the tank is full.
It would have to add a serious choke point to reduce the flow rate enough to be significant, though, as the flow rate is less than 8.5 ounces per minute at 120mph, assuming 30mpg.
« Last Edit: January 09, 2016, 11:11:07 AM by WintrSol » Logged
knockdolian
« Reply #4 on: January 09, 2016, 01:54:43 PM »
Found this on youtube. he seems happy with it
https://www.youtube.com/watch?v=AwRaa-37UP4
