February 11, 2026, 09:56:34 AM
99 I/S gauges not working
Topic: 99 I/S gauges not working (Read 809 times)
abrock52
January 15, 2016, 09:13:16 AM »
I posted back in September about my speedometer, odometer, and tachometer not working. I still have not found the problem! I have 14.5 volts coming out of the alternator. I have 12v at the back of the gauge cluster and I have continuity between ground and harness at the back of the gauges. The trip shows the numbers but doesn't count accurate. Please help! Can't afford $95/hrs to have dealer diagnosis. Plus I have checked all the fuses. I have been riding it since then with groups due to I have no speedometer
davit
Deerfield, WI
Re: 99 I/S gauges not working
January 15, 2016, 09:43:51 AM »
I can't help you with the gauges but if you have a smart phone there are plenty of speedometer apps. I use
a Ram Mount X-Grip to hold my phone.
abrock52
January 15, 2016, 09:52:30 AM »
I have been using my phone. It works pretty good but I just like to have the gauges fixed
mustang071965
those that dare, Succeed.
monticello Ar
January 15, 2016, 11:13:19 AM »
have you checked the speed sensor on the frt wheel. also crazy question, does your radio, fuel gauge and dig display work? or is just the clock showing?
Last Edit: January 15, 2016, 11:23:43 AM by mustang071965
January 15, 2016, 05:45:40 PM »
You also haven't posted where you live yet. It might help a little if someone is close by.
Last Edit: January 15, 2016, 05:53:36 PM by gordonv
abrock52
January 16, 2016, 06:44:11 AM »
Southern Indiana
Reply #6 on:
January 16, 2016, 07:51:34 AM »
There have been quite a few reports of problems similar to yours regarding the interstate. Most all
have been traced to a connector wrapped inside of the protective factory covering that resides in
the area below and behind the battery box. Fixing the connection THERE has been the cure.
Search and you may find other relevant threads.
