November 26, 2025, 09:23:11 PM *
Author Topic: Who sells the machined spacer for the double row bearing mod..saw it and...  (Read 1138 times)
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« on: January 17, 2016, 06:33:46 AM »
cant find it.
I thought it was redeye but nt listed on his site.
Thanks in advance!
« Reply #1 on: January 17, 2016, 06:37:55 AM »
Grumpy
big poppa pump
San Antonio, TX
« Reply #2 on: January 17, 2016, 06:40:00 AM »
Contact Grumpy.
http://www.valkyrieforum.com/bbs/index.php?action=profile;u=559
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #3 on: January 17, 2016, 08:27:44 AM »
You can call Bill (Grumpy), but I just ordered a new one and took it to a machine shop.  Not expensive.  Then, when I did the job on bike one, I took bike one's spacer back to the machine shop for bike two.
RDKLL
Mesa, AZ
« Reply #4 on: January 17, 2016, 08:32:29 AM »
Thanks everyone...I knew it was one or the other
Brian
Monroe, NC
« Reply #5 on: January 20, 2016, 04:13:21 PM »
You can get your OEM spacer machined down. I would recommend checking with your local maw and paw machine shop or a nearby tech school.
« Reply #6 on: January 20, 2016, 05:54:17 PM »
This is true.  If you don't want to wait for it, Order one on line or at the dealer, have it machined, I believe the finished dimension you want is 0.625 or 5/8 in.  (some one correct me if I'm wrong).  They aren't that expensive.  That way you have it on hand and can change it at your leisure.
« Reply #7 on: January 21, 2016, 06:47:57 PM »
Taken from the posting in ShopTalk,
The 5204/3204 bearing is 20.6mm wide while the 6204 bearing is 14mm wide. In
English measurements, this is a .260” difference. You have to get that removed from the small
end of the space.
N0tac0p
« Reply #8 on: January 22, 2016, 04:41:43 AM »
whats the importance of this non OEM mod? and does one wait or..?  ill look into shop talk
« Reply #9 on: January 22, 2016, 11:39:10 AM »
What's the importance of this non OEM mod? and does one wait or..?  ill look into shop talk
Because enough of us had the left rear single row bearing fail (and almost never the double row right bearing) (me too, way the heck out in nowhere), that someone came up with a way to prevent it.
It's been a few years now, and no one has yet reported a modded double row left bearing (with machined spacer) failure.  Mine either.
I waited until I needed a new rear tire, on both bikes.
« Last Edit: January 22, 2016, 09:49:29 PM by Jess from VA » Logged
RDKLL
Mesa, AZ
« Reply #10 on: January 22, 2016, 07:49:41 PM »
Grumpy does not seem to be selling them anymore
« Reply #11 on: January 23, 2016, 05:42:22 AM »
It is not a complicated machining process.  If Grumpy in not selling them any more, Buy a spare, and take it to a local shop.  I see the dimensions were posted above in reply #7.
Hell, if you were careful you could probably do it with a cut off wheel and grinder.
KG
Munford Tennessee
« Reply #12 on: January 23, 2016, 09:45:51 AM »
If your careful and keep it square to the spacer with a little time you can do it with a file.
What we do all have is a limited number of days to devote to whatever we love in this life.  Not all the same number of days but all have limited days....Willow
« Reply #13 on: January 23, 2016, 02:33:52 PM »
That'll work too!
