February 11, 2026, 01:54:55 PM *
Author Topic: how to set clock on 99 IS  (Read 3540 times)
Memor86
Tampico, Mexico
« on: January 18, 2016, 11:10:04 PM »
Hello.
I have tested the button with a multi-meter. it works also cleane all of the switches with contact cleanner.
while cruising i can switch between the FM frequency and the clock with the button.. but how do you set the clock? i have pushed the button for like one minute and it never starts blinking to change the time. with bike on and off, radio on and off. just wont work. is there any trick??
mark81
Cincinnati Ohio
« Reply #1 on: January 19, 2016, 12:03:21 AM »
Just ignore the clock. I set mine several times and after less than a month its off by at least 20 minutes.
1997 Honda Valkyrie
1981 Honda CB750 Custom
Earl43P
Farmington, PA
« Reply #2 on: January 19, 2016, 05:59:26 AM »
From an old post:
Clock
Turn the key on or to ACC> Radio ON > Push and hold the CLOCK button until you hear a beep and the display starts blinking > Operate the VOLUMN lever to adjust the time, push the volume lever up and hold it until you reach the desired hour, then push the volume lever down and hold it until you reach the desired minute > Push the CLOCK button again to lock in the time display.
Mine works well, keeps accurate time between Daylight Savings Time changes, give or take a minute or two.
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
Cracker Jack
« Reply #3 on: January 19, 2016, 09:14:07 AM »
Hello.
I know you have tried a lot of things without success. If the following doesn't work, you've got a real problem.
Make sure the AM/FM radio is on. The time must be showing, if the radio frequency is showing, push the clock button so that the time is showing. Then press and hold the clock button until it starts flashing. Mine starts to flash within about three seconds. If this doesn't work, I'd say you have a clock issue. Good luck. cooldude
Memor86
Tampico, Mexico
« Reply #4 on: January 19, 2016, 02:41:31 PM »
Where is the clock circuit? i am guessing it is inside the radio box.. because when i had the radio thing under the seat disconnected nothing would show on the lcd.
« Reply #5 on: January 19, 2016, 05:00:54 PM »
Do you not have the owner manual?
If not, send me an email. I scanned the pages to do with the radio controls, into a PDF format.
Memor86
Tampico, Mexico
« Reply #6 on: January 20, 2016, 04:09:10 PM »
i've got it, thank you. last time i tried to set the clock it was with the radio off. i will try with the radio on.  Cheesy
