August 28, 2025, 06:45:30 PM *
Author Topic: My latest tail lighting RR-TT-BB set up and short video  (Read 995 times)
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« on: January 22, 2016, 07:52:34 PM »
Yes I had taken it down, was going to delete but it would not let me...
« Last Edit: January 26, 2016, 03:23:23 AM by RDKLL » Logged
« Reply #1 on: January 25, 2016, 06:20:41 AM »
Doesn't look safe, I can barely see anything
mark81
Cincinnati Ohio
« Reply #2 on: January 25, 2016, 10:09:21 AM »
he went a bit to far with the bobber project. there is nothing left of it, he must have cut the frame stubs off finally.
1997 Honda Valkyrie
1981 Honda CB750 Custom
RDKLL
Mesa, AZ
« Reply #3 on: January 26, 2016, 03:24:51 AM »
Haha, I guess the ... would be unsafe. And I have not cut the stubbies yet.
And cant load the video
jdp
« Reply #4 on: January 27, 2016, 07:57:03 AM »
Man hope you don't hit a bump and land on that tire with your bum
Lyonardo
« Reply #5 on: January 27, 2016, 09:07:12 PM »
Hey man, I really want to see what you've done.
Can you put it on Youtube and just give us the link?
L
RDKLL
Mesa, AZ
« Reply #6 on: January 28, 2016, 03:38:31 AM »
You mean how I did it or what it looks like operating? I had no intention of getting 2 sets but because U jacked up the hollow threaded parts of one set, I ordered a new set and then found out they make "adapter studs" so I ordered a set of thos and ended up with 2 sets. I initially had drilled holes in the frame stubbies...then I decided to move them to the upper bolt of the passenger foots rest mounting point with the aid of a 30mm stand off so you could see it past the shock. Now that they are both on the upper shock, might do a little shimming to line them up vertically
Pic number 1
Pick number 2 was the mock up of 2 sets
Then moved them both up to the upper shock mount
« Reply #7 on: January 28, 2016, 04:17:24 AM »
I think your last setup looks the best  cooldude
