January 29, 2026, 06:18:38 PM *
Author Topic: Dial-a-Jet People  (Read 2163 times)
dreamaker
Harrison Township, Michigan
« on: September 14, 2009, 11:57:38 AM »
Has anyone with Dial-a-jet on there bike had issues with there bike. Not major problems, just seeming to change in performance.  Maybe seem to run perfect one moment and seemed a little off the next.
Dan
TearlessTom
Spanish Fort, AL.
« Reply #1 on: September 14, 2009, 12:22:20 PM »
I had one on my VT750 and loved it. It was actually fun to play with. Depending on the setting I could get good strong pull through all rpms or I could change it and it would pick up at a higher rpm and it felt like a 4-barrel kicking in.
I never had any erratic behavior but it does take a little playing with to find the best setting for your type of riding.
I plan on getting some for the Valk one day.
Tom
Dag
Country Rep. Norway
« Reply #2 on: September 14, 2009, 01:19:05 PM »
No problem at all, I love it  cooldude
dreamaker
« Reply #3 on: September 14, 2009, 02:41:34 PM »
I'm not saying the Dial-a-jet is the problem, just trying to figure my problem. Here is the deal !! My bike ran great last year.  This year it ran odd, I think we can all agree when a Valk is running good it has a hum to it, pipes or no pipes.  Mine hums then seems to get a slight flutter to the sound, kind of an off sound, not a miss sound. I have changed every rubber piece on the bike. cleaned the tank and changed the filter. I added an in-line filter which was suggested on a thread to have plenty of flow. Didn't clean the jets, I replaced them. I tested for vacuum leaks also the petcock diaphragm, cleaned and recharged the K&N air filter. Checked the coils and plug wires. I synced the carbs about five different times.  The thing is it is not consistent pattern, its there and its not there. I may take off and it will run fine, then I could stop for a red light and the flutter appears, then the next light it may disappear. I thought temp. maybe a factor but it may do it hot or cold. For me this is a real hair puller .  The thing is if you didn't own a Valk you may never notice it. The reason I asked about the Dial-a-jet is when I played around it using Dag's idea and changed it back it seemed to get worst. That why I thought the DAJ may have something to do with it.
Thanks for you input.
Dan
Dag
Country Rep. Norway
« Reply #4 on: September 14, 2009, 03:03:36 PM »
Have you checked the DAJ nozzles? They could be glogged.
I have not had that problem, but I take them out and clean them every winter.
Also the air intake filters on the DAJ could cause a problem if they are dirty. I change them once a year.
scorpio
« Reply #5 on: September 14, 2009, 07:53:49 PM »
I have had Dial-A-Jet for two seasons now with no problems. Have not done anything other than play with settings a little. We have ethanol in the gas so I use Sea Foam in the spring for a while. Overall I'm satisfied with mine.
humshark
Spring Hill Tennessee
« Reply #6 on: September 14, 2009, 07:54:35 PM »
Mine seem fine.  I agree with the earlier statement about playing with the settings to get a different response.
I also have periods of "off" performance - but have always worked it out with Sea Foam and the like.  This newer gas is KILLING me!
99 Interstate
05 FJR
97 Vulcan '88' Hacked
Dag
Country Rep. Norway
« Reply #7 on: September 16, 2009, 04:02:01 AM »
I will have a Dyno test wednesday next week.
Do any of you have a dyno chart?
As many as possible for comparison.
What we need to know is:
*K&N Air filter?
*Aftermarket exhaust? Brand?
*Exhaust mod? Glasspack? Cut Piggies?
*Dyna 3000?
*Jet Kit?
*IS Springs?
*Airbox modifications?
*De-smog?
*Jet size?
Did I forget somthing?
Please post your Dyno Chart (or email it to me [dve@online.no] if you want to be anonymous)
« Last Edit: September 16, 2009, 05:56:31 AM by Dag » Logged
dreamaker
« Reply #8 on: September 16, 2009, 05:25:54 AM »
I have :
K&N filter
Ext. Mod. Glass-pack
2000 I/S Carbs
2000 I/S Module
De-smog
Factory jet kit
Dial-a-jet
38 slow 95 main
Going to soak DAJ needles today and resync.
Dan
Dag
Country Rep. Norway
« Reply #9 on: September 16, 2009, 06:10:51 AM »
1997 Tourer
Thunder Pipes
Lamonster Supercharger
!!!  TORQUE IN NM !!!
Black Sled
« Reply #10 on: September 16, 2009, 03:12:22 PM »
Dag - I am looking forward to seeing your dyno results - please do post that.  I am particularly interested in the air-fuel ratio.  If the DAJ functions as advertised, the AFR should be pretty constant.
Black 2000 Valk Tourer (my black sled)
Dag
Country Rep. Norway
« Reply #11 on: September 16, 2009, 04:11:15 PM »
I will post the result.
The Levis 501 Dyno tells me that I have better performance with the DAJ, "butt" not the exact numbers.
I know the result will be good. Compared with other Valks I have tried, mine is definitely the fastest. (with the exception of Knut Olav`s blown Valk)  Smiley
