January 29, 2026, 06:18:29 PM *
Author Topic: Battery problem  (Read 1811 times)
Baloo
Rimouski, Canada
« on: September 14, 2009, 04:11:30 PM »
Hi guys,
This morning, my big lady decided that I would go to work in my cage and certainly not on her back. Last time that I rode her was last Friday night and all was fine, except that I noticed that the led on the back on my RH mirror did not work anymore. So on Saterday night, I checked the light problem and found 2 broken wires. Repaired them, problem solved. I let the switch on maybe a total of 4 or 5 minutes(engine off), just the time to check for power and then switch back off. Went to start this morning, she was cranking, but slower than normal and rapidly, the cranking speed went down. I did not insist and did not have time to check it right away, so I jumped in the cage and went to work. On my return tonight, I removed the seat and jump started her from my non running car. She started right up. I let her run for 3-4 minutes, then I hooked my voltmeter to the battery posts. Reading: 17.9 V. I turned the key off and tried to start her again and she started just fine. I guess I'm off for a new battery. (Not sure about the age of this one, as I'm not the original owner) My question is: Is it normal to get a reading like this on a discharged battery? I know that a normal charging voltage is around 14.5 V, but does it get higher when the battery gets low? I'd hate to buy a new battery and then fry it with an overcharging alternator  uglystupid2
Thanks for any advice!
Never ride any faster than your guardian angel can fly...
« Reply #1 on: September 14, 2009, 05:07:48 PM »
Double check your meter by checking your car's battery. If it's 17.? ; then get a new battery. If not: then check out the charging system.
fiddle mike
Nothing exceeds like excess.
Corpus Christi, TX
« Reply #2 on: September 14, 2009, 05:14:03 PM »
The last time I saw a regulator output of over 16V was on wife's Honda Magna. It cooked her battery and both battery and regulator had to be replaced.
« Last Edit: September 14, 2009, 05:15:49 PM by fiddle mike » Logged
