August 28, 2025, 08:47:09 PM *
Author Topic: Ignition Switch  (Read 642 times)
indybobm
Franklin, Indiana VRCC # 5258
« on: January 30, 2016, 12:32:46 PM »
Can an ignition switch from an Interstate be used on a STD/Tourer? Are the plugs the same?
I think the I/S switch has an Accessory position, does that do anything on a Tourer?
So many roads, so little time
VRCC # 5258
« Reply #1 on: January 30, 2016, 01:52:19 PM »
According to the wiring diagrams, the IS switch and connector should be able to work on a Std/Tourer.  The IS has two connectors, one with 4 pins same as the Std., and one single wire connector for the accessory power.
indybobm
« Reply #2 on: January 30, 2016, 03:54:31 PM »
Thanks, much appreciated.
VRCC # 5258
