August 04, 2025, 12:31:30 AM *
Author Topic: Project Bike  (Read 2382 times)
Big Ed
2001 Standard - 1998 Project Bike
Dallas - Fort Worth, TX
« on: February 03, 2016, 03:39:43 AM »
Hello all,
I'm picking a black 97 Standard today and going to trailer it home. It has no key, hasn't been started in about 3 years. I figure carbs are bad. Going to take off tank, change engine oil and filter, coolant, clutch and brake fluids. Will also have to buy a battery of course. Any advice on the carbs or other items. I havent even seen it yet. Supposedly lots of chrome. Garage kept. Will post pics later.
Thanks...
« Reply #1 on: February 03, 2016, 04:50:31 AM »
Hello all,
Thanks...
I haven't taken apart a set of Valkyrie carburetors, but there's lots of searchable info
on this site. A site vendor sells an "easy good" carburetor sync tool. Another top-notch
mechanic/poster has gone to ultrasonic (instead of solvent) cleaning...
It is real easy (compared to rebuilding the carburetors) to remove the calipers and
clean-refurbish them, I've seen some awful goo inside them that wouldn't be addressed
by just bleeding in some new fluid.
-Mike "start out with good brakes..."
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #2 on: February 03, 2016, 05:41:31 AM »
Congrats Ed, I've had a blast restoring my rescue bike.  For the carbs I suggesting draining the tank if there's anything in there, refill about half way and dump in a couple of cans on Berryman's and run her around the block a few times.  This procedure saved me from rebuilding my IS carbs and she's been running great for almost a year now.
I agree with hubcap but I'll take it further and suggest you change every fluid on the bike before you run her around the block.
Big Ed
« Reply #3 on: February 04, 2016, 04:33:22 AM »
f-Stop
'98 Standard named Hildr
Driftwood, Texas
« Reply #4 on: February 04, 2016, 06:20:16 AM »
Looks like she's in pretty good shape.  You should probably consider replacing the vacuum hoses, fuel lines and cover set.  Easy to do once you've got the tank off.  Also, maybe replace the fuel strainer on the petcock.
Congratulations!
 Smiley
Big Ed
« Reply #5 on: February 04, 2016, 09:01:06 AM »
Congratulations!
 Smiley
Thank you. I think we need a wrenching party at my house once some nicer weather comes around.  Shocked Shocked Shocked Shocked Shocked Shocked
Big Ed
« Reply #6 on: February 04, 2016, 09:05:00 AM »
and it needs a car tar...!!!
Big Ed
« Reply #7 on: February 04, 2016, 09:06:38 AM »
Correction: Hasn't been started in 18 months.
Disco
Republic of Texas
« Reply #8 on: February 04, 2016, 11:11:37 AM »
Congratulations, Ed!
Although not in the football, both of those are in the club and available for local use.   Wink
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
BnB Tom
Where'd old times go?
Frisco, TX
« Reply #9 on: February 05, 2016, 04:06:15 AM »
When you get around to it...  I might be able to help you with the "no key" problem.   Cool
I know that's not high on your priorities but when you have the time you'll need to pull the ignition and get the inards to me.  If you have problems doing that part, let me know when your wrench party is and I'll come pull it for you.  Smiley
Big Ed
« Reply #10 on: February 05, 2016, 05:15:08 AM »
Thank you my friends...!!!
Red Diamond
Beaumont, Texas
« Reply #11 on: February 05, 2016, 08:36:50 AM »
Tom you can get a key made without taking it apart. Get the code to a locksmith.
« Last Edit: February 05, 2016, 08:39:19 AM by Red Diamond » Logged
Big Ed
« Reply #12 on: February 05, 2016, 02:04:51 PM »
How do I find the code?
chauffeur
Mansfield, Texas
« Reply #13 on: February 05, 2016, 03:42:51 PM »
take the chrome cover off of the ignition housing.
Red Diamond
Beaumont, Texas
« Reply #14 on: February 05, 2016, 05:46:37 PM »
As was stated by Dave, remove the chrome cover and the screws holding the ignition switch. Turn the switch over to see the code which you can give to a good locksmith and have another key made. Good luck.
Big Ed
« Reply #15 on: February 06, 2016, 01:25:26 AM »
Awesome. Will do. Thanks...!!!
BnB Tom
Frisco, TX
« Reply #16 on: February 06, 2016, 03:24:44 AM »
  Really  Wink
Red Diamond
Beaumont, Texas
« Reply #17 on: February 06, 2016, 07:26:03 AM »
  Really  Wink
Really.
BnB Tom
Frisco, TX
« Reply #18 on: February 08, 2016, 03:53:11 AM »
  Anyway Ed.
If you have any problems getting a key made, let me know.  Wink
Big Ed
« Reply #19 on: February 09, 2016, 12:03:35 AM »
I'm working on it. Will keep everyone posted. Thanks.  Smiley Lips Sealed
Big Ed
« Reply #20 on: April 06, 2016, 04:39:52 AM »
So haven't done any on the bike yet except remove the dead battery. This morning I went to change the oil and filter. To my amazement the oil came out super thin and more than twice as much as there should have been in there.
Not sure if it smells like gas mixed in with the oil but it might be. So question. Did the bike hydrolock and seller conviniently forgot to tell me? The story was it was sitting storage unused for 18 months then the key got lost.
Could a bowl have stayed open just do to sitting idle for so long and gas got into the oil?  Can something be cracked somewhere?
I'm not sure what to check or do next besides remove the gas tank and look around.
Help please. Thanks...
« Reply #21 on: April 06, 2016, 05:42:36 AM »
It is kind of a drag to remove (and reinstall) the starter, but
you could look in there and know one way or the other about
hydrolock damage...
I guess it would be pretty easy for stuff to drain past the
petcock and some carb floats into some top-ends on a sat-up
bike... I don't know if it would flow past there into the bottom
end, though...
Houdini
Allen, TX
« Reply #22 on: April 06, 2016, 06:39:53 AM »
Ed, fuel sitting in the combustion chambers will eventually leak past the rings and into the case.  If it was mine I'd replace the oil, remove the spark plugs, and hit the starter button.  You'll know right away if their is too much fuel in the cylinders, it'll spray a lot of fuel out, and/or hydrolocked, 'cause it won't turn over.
FWIW, don't turn her over without removing the spark plugs first or you risk hydrolock.
Big Ed
« Reply #23 on: April 06, 2016, 07:05:26 AM »
Big Ed
« Reply #24 on: April 07, 2016, 04:26:57 PM »
So theorectically the entire gas tank could have drain down to bottom on the engine thru 1 carb and cylinder?
RainMaker
Arlington, TX
« Reply #25 on: April 07, 2016, 05:08:58 PM »
In theory, yes.  And if true, the chance that the empty tank is rusty inside goes up exponentially.
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
Big Ed
« Reply #26 on: April 14, 2016, 02:27:59 PM »
Quote from: RainMaker link=to.  :oc=84413.msg845764#msg845764 date=1460074138
Feeling a little bit worried...
Big Ed
« Reply #27 on: June 02, 2016, 03:10:26 PM »
Rainmaker was correct. Rust inside the tank. Just bought the Kreem Reliner Kit for $47 to begin the rust removal and re-lining process.
I was hoping to get away without having to rebuild the carbs. I guess I'm not going to be that lucky.
Thoughts...???
« Last Edit: June 03, 2016, 08:47:03 AM by Big Ed » Logged
RainMaker
Arlington, TX
« Reply #28 on: June 03, 2016, 05:26:31 PM »
Thoughts...???
I've got some carbs to rebuild on the Tourer that sits and takes up space in my garage.  We could make mistakes together!
2005 BMW R1200 GS
1972 CB500K1
