January 29, 2026, 06:18:31 PM *
Author Topic: More about the "Darkside"  (Read 2124 times)
Earl in Pensacola
« on: September 15, 2009, 10:21:41 AM »
I've pretty much decided to give the darkside a try, namely a 195/60R16.  The problem is finding one!  I wnat to phycially see, touch and measure one before ordereing on:  The second problem:  The shops here in Pensacola (Sears, Pep Boys and Vannoys, a local tire shop) all think the tire is made of gold.  The quoted prices ranged from $132. to $159. plus taxes and fees!!  Yet I can buy a bigger tire (Top level Michilin) for my truck for $99.00!!
So, the question is, where did you guys buy or ordered yours, if any of you are using the 195/60R16.
Bone
« Reply #1 on: September 15, 2009, 10:51:42 AM »
Tirerack.com
I've been using them for some time. My Jeep and now the bike. I have had good quick service.
« Reply #2 on: September 15, 2009, 11:20:55 AM »
Yep, go online.   Google 195-60-16 and you will be surprised all the leads. E-Bay the same.  Can't go wrong.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #3 on: September 15, 2009, 11:36:03 AM »
Hey Earl,
Just use any tire website and do a "search by size" You can search by brand ect... I use tire rack, I did a quick link for you by size... http://www.tirerack.com/tires/TireSearchResults.jsp?width=195/&ratio=60&diameter=16&x=55&y=9 The size you are asking about seems to be available. Most go with the 205 on the Valk.
Have fun Wink
Earl in Pensacola
« Reply #4 on: September 15, 2009, 12:29:22 PM »
Thanx.  I'll check it out now.
Ken Tarver
North Mississippi
« Reply #5 on: September 15, 2009, 02:18:33 PM »
195/60-16 is going to be about 1" less overall diameter that stock valk tire
Ken
Ken Tarver
North Mississippi
« Reply #6 on: September 15, 2009, 02:31:49 PM »
205/60 is about the same overall diameter
DFragn
« Reply #7 on: September 15, 2009, 04:28:06 PM »
Ken
Re: More about the "Darkside"
« Reply #6 on: Today at 04:31:49 PM »
I'm sure you meant  diameter width = 195 or 205 in this case. 60 is the profile [rim to tread] & a 205 is quite a bit wider then the stock 180.
A 195/60-16 is very close to stock. Just a bit wider.  Wink
« Last Edit: September 15, 2009, 04:30:04 PM by DFragn » Logged
« Reply #8 on: September 15, 2009, 04:36:50 PM »
for reference,
195/60-16   25.2 od, 6.1 wide
205/60-16  25.7 od
205/65-16  26.3 to 26.5 od,  6.2 to 6.4 wide
stock oem dunlop  26.02 od,  7.09 wide
E3     26.06 od,  7.13 wide
Disco
Republic of Texas
« Reply #9 on: September 15, 2009, 04:44:15 PM »
I'm sure you meant  diameter width = 195 or 205 in this case. 60 is the profile [rim to tread] & a 205 is quite a bit wider then the stock 180.  A 195/60-16 is very close to stock. Just a bit wider.
I'm pretty sure Ken meant diameter.  You're right that the "60" is the profile [rim to tread].  The "60" is really the aspect ratio of sidewall height to tread width meaning the sidewall height is 60% of the tread width.
For the stock 180/70-16, the width is 180mm and the sidewall height is (180mm x .70) = 126mm.
For a 205/60-16, the sidewall height is (205mm x .60) = 123mm - 3mm shorter in radius / 6mm shorter in diameter.
A 195/60-16 will be 9mm shorter in radius / 18mm shorter in diameter.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
