February 11, 2026, 01:46:52 PM *
Author Topic: Indicator lights  (Read 883 times)
Romeo
J.A.B.O.A.
Romeo, Michigan
« on: February 18, 2016, 04:26:02 AM »
Can anyone tell me, what do the three indicator lights, the blinker, neutral and bright indicators, have in common electrically? Mine all went out. I look at the schematic and I don't see it.
crash1980
« Reply #1 on: February 18, 2016, 04:49:26 AM »
I'm sure someone with more knowledge than I have will come along, but don't they all connect as a single harness connector?
indybobm
Franklin, Indiana VRCC # 5258
« Reply #2 on: February 18, 2016, 05:08:47 AM »
They all connect to the bike through the 6 pin green connector in the headlight shell. Maybe it is disconnected.
« Last Edit: February 18, 2016, 05:16:20 AM by indybobm » Logged
So many roads, so little time
VRCC # 5258
« Reply #3 on: February 18, 2016, 05:21:43 AM »
10A fuse labeled "TAIL METER"
indybobm
« Reply #4 on: February 18, 2016, 05:48:30 AM »
Could be but I think other things would not work if that fuse was blown. I think that the Hi-Beam Indicator is actually powered by the headlight wiring through the Hi-Lo switch, Start Button to the 10A Headlight fuse.
« Last Edit: February 18, 2016, 06:03:56 AM by indybobm » Logged
VRCC # 5258
Romeo
J.A.B.O.A.
Romeo, Michigan
« Reply #5 on: February 18, 2016, 10:00:32 AM »
first thing I checked. Tail light works, fuse is ok. Probably that connector in the headlight bucket. She's pretty full  now that I have the LED in there. Maybe I somehow disconnected it. Guess I need to pull it back open.
