February 11, 2026, 01:47:07 PM *
Author Topic: Converting I/S to all LED  (Read 819 times)
Dak44312
Akron, OH
« on: February 18, 2016, 09:10:39 AM »
A couple years ago, I converted my Standard to all LED and now I want to do he same with my I/S (minus the trunk). When I did the conversion, I used an electronic flasher and I also had to solder a diode in the headlight harness assembly to prevent bleed though from the indicator light. I searched, but I can't find any info on whether the I/S will need the same thing? Since the I/S uses 2 indicators instead of one, do I even need to use a diode?
big poppa pump
San Antonio, TX
« Reply #1 on: February 18, 2016, 09:16:51 AM »
No, the diode is required only for a single turn indicator.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
NighthawkVTX
Gainesville, Fl
« Reply #2 on: February 18, 2016, 09:21:38 AM »
Just curious, why did you need a diode? Not sure what you meant when you said bleed from the indicator?
If at first you don't succeed, then perhaps skydiving isn't for you
Paladin528
« Reply #3 on: February 18, 2016, 09:27:39 AM »
With a single indicator on the tree, the power bleeds across the indicator lamp to the opposite side and causes all lamps to flash.  You actually need 3 diodes to correct the issue as well as running one side of the indicator lamp to ground.  Kuryakyn makes a kit for doing this.  The Valk shouldn't need it
big poppa pump
San Antonio, TX
« Reply #4 on: February 18, 2016, 09:56:36 AM »
You don't need 3 diodes, you only need 2, 1 goes to the orange and the other to the blue wire. The 2 diode kits cost less than 5 bucks at superbrightleds.
VRCC#35870
VRCCDS#0266
Paladin528
« Reply #5 on: February 18, 2016, 10:09:05 AM »
my bad you are correct.  It was converting the turn signals to running lights/turnsignals that required 3 diodes
Dak44312
Akron, OH
« Reply #6 on: February 18, 2016, 11:14:04 AM »
Thank you much!
