November 26, 2025, 10:43:18 PM
Dumb horn question 1500
Topic: Dumb horn question 1500 (Read 649 times)
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
February 27, 2016, 10:24:34 AM »
Going back to a stock horn, that I do not have yet but is on the way. I take it the stock horn uses the mount as the ground and I only have one wire for hot? Current horn uses a hot and ground wire and I want to run a new wire wile I have the tank off for other work. So I assume I only need to run one wire?
big poppa pump
San Antonio, TX
Re: Dumb horn question 1500
February 27, 2016, 10:42:50 AM »
There are 2 wires to the oem horn, both of which are black in color. If you have an aftermarket horn, more than likely it's connected to a relay and that's why you have a (+)ve and a (-) ve going to it.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
_Sheffjs_
Sarasota FL
February 27, 2016, 11:59:26 AM »
you saved me a do over.
=> InZane XXV
