February 11, 2026, 05:15:01 PM *
Author Topic: Won't start, electrical  (Read 1164 times)
Duffy
Atlanta, GA
« on: February 28, 2016, 12:00:10 PM »
I've had my 93 Valk on the trickle charger, cranked right up then died. Starter fired one more time then dead. No power. GPS had power from battery. Idiot lights no power, neutral light out for sure.
Checked "main" fuse, good. (meaning the 30A hidden behind the side cover). Then there is the 55A metal strip there too, looks good.
Ideas on what to check next? I am an idiot when it comes to electrical...
« Reply #1 on: February 28, 2016, 12:18:31 PM »
Jump it to the car and see if it starts... If it does it's a bad battery
Duffy
Atlanta, GA
« Reply #2 on: February 28, 2016, 12:35:42 PM »
I am loosing it, I stated '93 Valk! I mean 2003 Valk, aka Charlene.
Battery not likely. I have started from the car before, not recently.
Duffy
Atlanta, GA
« Reply #3 on: February 28, 2016, 01:07:50 PM »
Well, I was reluctant to jump it, because I was SURE it wasn't the battery...
It started with a jump. Dead batter it is! Thanks Chris!
« Reply #4 on: February 28, 2016, 01:17:48 PM »
Good deal
« Reply #5 on: February 28, 2016, 01:22:38 PM »
You could also have a charging problem.  Check voltage at the battery terminals when the bike is running at 2000 RPM.  Should be above 13V.
Duffy
Atlanta, GA
« Reply #6 on: February 28, 2016, 07:09:54 PM »
You assume I can read the old analog volt meter I have... Undecided
« Reply #7 on: February 28, 2016, 07:52:46 PM »
Turn the dial to DC volts in the 0-25 range. Then on the face there will be several lines, one of them will be that 0-25 DC. If all else fails you can get digital meters really cheap at Harbor Freight.
Moonshot_1
« Reply #8 on: February 29, 2016, 01:59:11 PM »
Was going to suggest Flux Capacitor but ... 2funny
Mike Luken
Cherokee, Ia.
« Reply #9 on: March 01, 2016, 04:10:37 AM »
That is correct though, anytime you have a dead battery you should make sure the alternator is not the cause.  However, if it starts right up with a new battery it will only take a couple days of use to kill the new battery if the alternator is not charging.  So, a week or so of use after the new battery If it still starts you have some charging going on.
Duffy
Atlanta, GA
« Reply #10 on: March 06, 2016, 07:15:43 PM »
Thanks guys for the additional comments on this thread, including the humor and the specific explanations.  cooldude
I had a great ride yesterday with the N Georgia Motorcycle Club and the new battery was great.
You are right though, I should test the battery now as you have explained before the inevitable if it is the alternator. I will hopefully get to that this week.
Just wanted to say thanks for the help.  Wink
« Reply #11 on: March 06, 2016, 08:00:51 PM »
Good to see that I'm not the only electrical dunce on this board  cooldude
« Reply #12 on: March 06, 2016, 08:02:42 PM »
It was good to meet up with y'all at TWO for lunch.
I only took us on 2 dead end U turns after lunch. Pretty low considering what can usually happen when exploring.
john
tyler texas
« Reply #13 on: March 06, 2016, 10:35:20 PM »
did you check/clean negative battery cable where it grounds to motorcycle ? take it off and scrub with wire brush
vrcc # 19002
