November 26, 2025, 10:44:46 PM *
Author Topic: Max. Front and rear tire size  (Read 2067 times)
bearcat
« on: March 01, 2016, 05:34:26 PM »
I have a 1997 tourer & wanted to know how wide a rear tire , also how tall a frt. tire I could put on. Has anyone dropped the rear with shorter shocks, how low can you go, thanks for the info.
« Reply #1 on: March 01, 2016, 05:38:40 PM »
Don't really know about the Max tire sizes but you can lower it with shorter shocks but then you can bottom out easier. My question would be why? I think Honda got the height correct.
bearcat
« Reply #2 on: March 01, 2016, 06:02:35 PM »
I have seen that look on other bikes & wondered if anyone had tried with a valkyrie. I didn't want to go extreme , just a little wider rear & a taller frt. tire. I don't want to neg. effect the driveability so that's why I asked, thanks.
h13man
Indiana NW Central Flatlands
« Reply #3 on: March 01, 2016, 06:05:14 PM »
Also departure from the 180/70 diameter will effect your final output/rpm's.
« Reply #4 on: March 01, 2016, 06:09:56 PM »
People have put a 200 size tire on the rear with no problems.  An Elite III is about as big a front tire as you can put on the front without taking the front fender off.
You can put as short as 11.5 inch shocks on with any problems....however, the bike will bottom out a lot easier.  I have 11.5's on mine and it's only bottomed out only a couple of times riding two up.
bearcat
« Reply #5 on: March 01, 2016, 06:25:19 PM »
I'll check that out thanks for the help .
« Reply #6 on: March 01, 2016, 07:32:08 PM »
I run a stock size front tire but the rear is a car tire, 205/60r16 with 12" shocks. No problems.
