November 26, 2025, 10:43:28 PM *
Author Topic: 97 carb rebuild  (Read 1041 times)
moonride
« on: March 02, 2016, 04:47:45 PM »
Hi, I am about to rebuild the carbs on my 97 and would like some advice on where to purchase from. Thank you for your reply...Jeff
signart
Crossville, Tennessee
« Reply #1 on: March 02, 2016, 04:59:22 PM »
Red Eye Technical Service is the best place to get all gaskets and o rings you will need if you are just doing a clean up. (complete kit)
They also have the o rings for the intakes which you need to replace while you are in there.
CajunRider
Broussard, LA
« Reply #2 on: March 02, 2016, 05:55:32 PM »
Don't know if you're planning on any re-jetting (or just want to put in fresh jets)...
But...
Jets-R-Us sells jets for a lot cheaper than those "kits" you find online.  You do have to know what you're buying though, so make sure you do your homework.
http://www.jetsrus.com/
Sent from my Apple IIe
« Reply #3 on: March 02, 2016, 09:56:22 PM »
Why????
Also might want to replace the floats. It's looking as if they are a major contributor to hydro lock.
Steel cowboy
Spring Hill, Fl.
« Reply #4 on: March 03, 2016, 03:38:21 AM »
RedEye for the carb rebuild kit which includes the o rings for the fuel rails and hoses for the air cut offs. RedEye for the manifold gaskets too. Don't forget the float valves, which you can purchase on EBay, they are a must do in any carburator clean up or rebuild. If your going to be doing all this you might as well do the desmog too. I purchased all the above items from RedEye just in case, there's nothing worse than starting a project and getting cought with out all the parts needed to completed it. I did mine last month and the difference is night and day. I don't have the site for the float valves which I got from Grumpy. One tip I used Chap stick on my float bowl o rings because I reused them and I have no leaks.
2001 black interstate
2003 Jupiter Orange wing
moonride
« Reply #5 on: March 03, 2016, 04:24:55 AM »
Thanks for all the input, the issue is a leaking float valve on #5 carb and it looks like e-bay from your replys. Thanks again.
BonS
Blue Springs, MO
« Reply #6 on: March 03, 2016, 09:59:17 AM »
Here's a link for six float needles. They're K&L and they're perfect. The price is perfect too.
http://www.amazon.com/Supply-18-8955-Float-Needle-K3-Keihin/dp/B001KOD732/ref=sr_1_sc_1?ie=UTF8&qid=1457029262&sr=8-1-spell&keywords=valmyrie+float+needles
Steel cowboy
Spring Hill, Fl.
« Reply #7 on: March 03, 2016, 10:35:48 AM »
Thanks BonS that's were I got my float needles from, not EBay. My oops.
moonride
« Reply #8 on: March 03, 2016, 10:57:12 AM »
Hi I just ordered the same brand of needles on e-bay for $19 and change free shipping.
heavyd
« Reply #9 on: March 04, 2016, 08:46:01 PM »
I will 2nd or 3rd or 4th or whatever number we are at for redeye. I buy anything they sell when I am looking for parts, and I have always been happy. I have also used jet-r-us, iirc they are also the site that has a jet calculator to help get you in the right ballpark for any mods you may have done.
Memor86
Tampico, Mexico
« Reply #10 on: March 05, 2016, 09:11:36 AM »
i've rebuild my carbs using red eye's kit. its great quality, very expensive but you can forget about ur carbs like forever if u take good care of ur bike, please note that his kit does not include the float bowl gasket, red eye sells it separately though.
