November 26, 2025, 10:44:18 PM
Wiring for Fairings
Topic: Wiring for Fairings (Read 636 times)
RipVanWinkle
Wiring for Fairings
March 05, 2016, 08:12:36 AM »
Does anyone have any suggestions as to where to run the power wires from the radio through the aftermarket fairings. I have a 1999 Standard with aftermarket fairing similar to a woodys or hoppes. I am at the point where I need to drill into the fairing. I would like some opinions as to where a good spot would be. any thoughts or ideas? I have everything else covered with the exception of running power to the radio. once drilling a hole starts it is a once and done kinda thing and I want to gather ideas and be comfortable with it.
Last Edit: March 05, 2016, 08:14:17 AM by OneFast350Z
Re: Wiring for Fairings
March 05, 2016, 08:52:42 AM »
My woodys has a hole drilled under the left side of the radio.( 1/2" hole) and I ran my wires under the tank came out the front under the tank in front of the triple trees and up through that hole. I also used a piece of the flexible ( black ) conduit around the wires from front of tank up into the hole in the fairing. Do t even really notice them being there with the conduit over them.
=> InZane XXV
