November 27, 2025, 12:17:47 AM *
Author Topic: Mystery vacuum line  (Read 1120 times)
mrbug
« on: March 05, 2016, 09:33:11 AM »
I pulled the carbs out to fix a fuel leak.  This vacuum line came out but I don't remember where it went.  I have a 1999 Valkyrie Interstate.  The rear two intake runners have vacuum lines on them and the middle intake runner had a vacuum line on it.  Could this mystery line come from the middle runner?
https://www.flickr.com/photos/139652135@N04/shares/nc5s6D
https://www.flickr.com/photos/139652135@N04/shares/59KEx7
« Last Edit: March 05, 2016, 09:40:12 AM by mrbug » Logged
When in doubt, flat out!
« Reply #1 on: March 05, 2016, 10:17:46 AM »
# 6 intake should be hooked up to the OEM petcock with a line.
#3 & 4 should be hooked together.
Unless you have a CA model or you've desmogged
« Reply #2 on: March 05, 2016, 10:36:05 AM »
Intakes 1,2 & 5 should have caps on the pressure boost joints.
mrbug
« Reply #3 on: March 05, 2016, 11:00:10 AM »
How are you counting the runners?  The front and middle runner on the right side are capped along with the front runner on the left side.  I believe my rear two runners were hooked together.
mustang071965
those that dare, Succeed.
monticello Ar
« Reply #4 on: March 05, 2016, 04:11:47 PM »
The cyl numbers are as this 1,3,5 are one the right side. 2,4,6 one the left side of engine.  1 is the first runner on right. 2 is first runner on left
PhredValk
Edmonton, Alberta, Canada
« Reply #5 on: March 06, 2016, 11:04:45 AM »
Is there a vacuum hose attached to the little nipple on the underside rear of the tank? That may be the tank vent tube...
Fred.
VRCCDS0237
mrbug
« Reply #6 on: March 07, 2016, 07:00:38 AM »
Fred.
The hose runs up to the petcock, I just did not remember which runner it came off of.  I still believe it came off of the middle runner on the left side.  Really not sure what would happen if these hoses got mixed up.
