February 11, 2026, 05:14:00 PM *
Author Topic: Darkside Rub?  (Read 793 times)
mikeb311978
« on: March 06, 2016, 07:37:52 AM »
Hi I'm new and am seeking some help . I am switching to the darkside and have done the cage nut mod and was wondering about going further as I am a big guy at 350 and my girl is around 120 and am worried about rubbing I currently have a 205/60/16 goodyear triple tread mounted on rim but have not installed am currently waiting on bearings .  Will try others later after seeing many other posts. THIS is on a 2002 cd with leatherlike hardbags. WILL I HAVE TO DO SHIMMING OF RAILS AND ALSO I WAS CONCERNED ABOUT THE CAGE AROUND LIGHT HARNESS AS IT PROTRUDES OUT ALOT ANY INPUT WOULD HELP THANKS!!
Crazy Dago
Adamstown, Pa.
« Reply #1 on: March 06, 2016, 08:31:31 AM »
 cooldude With proper air pressure you won't have any problems. I have a 205/55/16 triple tread on  my 98 for 4 years with out any concerns. Enjoy the benefits of the DARKSIDE.  crazy2 CRAZY DAGO.
« Reply #2 on: March 06, 2016, 08:47:51 AM »
I've had different 205-65-16 in there with ZERP problems. If you can get 2 credit card thickness's between the swing arm and side wall on the drive shaft side yer good to go. Start out at 40 P S I or a tad or and find YOUR sweet spot for comfort and handling. Yer gonna hafta buy yer own cursed cookie!  2funny RIDE SAFE.
CajunRider
Broussard, LA
« Reply #3 on: March 06, 2016, 09:29:39 AM »
I shimmed the rails on mine along with the nut-cage mod.
Our vacation rides...
Me + Wife = 400 lbs (I won't say what the ratio is)
Saddle bags loaded to the top (10-20 lbs per)
Uni-Go trailer loaded to the top with luggage (50+ lbs tongue weight)
No issues with nut-cage mod and shimmed rails.  Both are easy to do.  May as well get it done while you have the wheel off.   cooldude
Sent from my Apple IIe
« Reply #4 on: March 06, 2016, 09:47:19 AM »
I've done nut cages on both bikes but I don't think I even needed to do that. I wouldn't do the shims unless you had to.
mikeb311978
« Reply #5 on: March 06, 2016, 10:04:40 AM »
Thanks guys !! I've been really worried about this but now I have confidence that it will be fine I love this bike so this will be great! Grin cooldude
