February 11, 2026, 05:14:02 PM *
Author Topic: Engine Ice  (Read 941 times)
robin
Get on it and RIDE!!
Hardwick NJ
« on: March 07, 2016, 03:49:56 AM »
If you had to would it be alright to add a little water to the radiator to bring the level up after losing some?
pancho
Bonanza Arkansas
« Reply #1 on: March 07, 2016, 04:12:07 AM »
Yes, it is OK, but you have to wonder where the missing coolant went, and how much are we talking about. It is best to use distilled water, (no minerals to participate out and be deposited into you're cooling system) and check your protection with a hydrometer after the bike has been run. Also make sure that the overflow tank is full to the cold line with a 50/50 mix, and that the line running to it from the radiator is clear. (under left side cover) If it is pinched where it runs under the front of the fuel tank, it will cause you to loose coolant, possibly other problems....
« Last Edit: March 07, 2016, 04:17:38 AM by pancho » Logged
robin
Hardwick NJ
« Reply #2 on: March 07, 2016, 04:25:11 AM »
Radiator cap was loose from me not making sure it was tight after opening it this winter
« Reply #3 on: March 07, 2016, 06:08:27 AM »
Read the specs on the Eng Ice bottle. They may not recommend adding any water. I seem to recall this info but at my age I lose my keys often.
pancho
Bonanza Arkansas
« Reply #4 on: March 07, 2016, 05:52:04 PM »
Engine Ice is a mixture of Propylene glycol and water,, deionized water. Adding more water water to it will change the freezing and boiling point, but a little will not significantly affect the overall performance. I believe the freezing point of the product is -26 degree F which means it is already more than 60 percent water. Of course you don't want to dilute it too much, but a few ounces to top off the radiator is no problem.
« Last Edit: March 07, 2016, 06:07:23 PM by pancho » Logged
« Reply #5 on: March 07, 2016, 08:57:55 PM »
I don't think you should have a 50/50 mix in the over flow, but the same product, Engine Ice, in there instead. You don't want to mix up the 2 different products.
pancho
Bonanza Arkansas
« Reply #6 on: March 08, 2016, 04:27:20 AM »
Your're correct gordonv,, you do not want to mix the two, I misspoke when I said 50/50,, hope I didn't cause any confusion robin.
