January 29, 2026, 04:47:18 PM *
Author Topic: Rusty bolts  (Read 1921 times)
Gore
Denver CO
« on: September 17, 2009, 11:38:26 AM »
No, not looking for a guy named that, more a question of rust on the 4 bolts on the final drive, where it bolts to the swing arm. They're rusty and semi corroded. I'm going to wire brush them and put it together. Should I WD-40 them, maybe a little oil or grease (or will that make them tend to want to come loose) or not worry about it?
My driven gear and final drive gear we totally munched due to no lube. I bought a whole final drive and driven gear (star) from pinwall for $150 that is in great shape. Thanks Daniel M and hubcapsc for your inputs     cooldude
We gonna ride or we gonna dick around all day?    Okay good, let me just finish my coffee, find my key, grab gloves, call the woman, top-off, check my . . . . . . .
Mikey
Winona, MN
« Reply #1 on: September 17, 2009, 12:01:22 PM »
If you don't want them to come out, I would use a Loctite Blue, and make sure you get a good dab of it, that will "seal" the threads, keeping corrosion out. If you are looking to be able to remove them without heat (or a breaker bar), I'd use regular old anti-seize.
Remember folks, street lights timed for 35 mph are also timed for 70 mph
VRCC# 30782
Daniel Meyer
The State of confusion.
« Reply #2 on: September 17, 2009, 12:10:45 PM »
Anti-seize is your friend here.
CUAgain,
Daniel Meyer
Blackduck
West Australia
« Reply #3 on: September 18, 2009, 09:01:05 AM »
Loctite "blue" or nutlock will work fine, as the previous post said will seal out moisture and if torqued correctly is no problem to undo when needed. Use it on all threads and never had any problems.
Cheers Blackduck
Farther
Quimper Peninsula, WA
« Reply #4 on: September 18, 2009, 09:43:59 AM »
Maybe replace the bolts with stainless versions if you can find ones with the right specs.
~Farther
« Reply #5 on: September 18, 2009, 02:09:26 PM »
Stainless is not a good choice. Stainless has higher fatigue factors and less strength that corresponding steel. Stainless threads seize and tear and do not lend themselves to repeated cycling.
