November 27, 2025, 12:17:48 AM *
Author Topic: Grinding on start  (Read 994 times)
dancnman
Houston, Texas
« on: March 14, 2016, 06:03:03 AM »
Yesterday, I started my Interstate and there was a kind of grinding gear/bearing noise that continued for a while then stopped.
I started the bike a few more times and I could not hear it anymore.
I started it again this morning and I get the same "Sounds of Death" from it until it runs for a couple of minutes.
The bike starts good, seems to run good, oil pressure light goes right off, but this noise is killing me.
Any ideas?
Jerry
Reality is that thing which does not change simply because I choose to ignore it.
Pete
« Reply #1 on: March 14, 2016, 06:35:06 AM »
Identify the area the noise is coming from and post it please.
« Reply #2 on: March 14, 2016, 07:35:20 AM »
It could be the clutch unit on the starter assembly. Get a piece of garden hose and listen there at the starter.
Tfrank59
'98 Tourer
Western Washington
« Reply #3 on: March 14, 2016, 09:19:20 AM »
I know there's debate about what to call this thing – I call it a starter Bendix – but is that thing sticking engaged when he releases the starter button?
OK correction I guess it's a sprague clutch – still think that's the problem --it's sticking when cold. Or maybe starter button just needs maintenance?
« Last Edit: March 14, 2016, 09:29:20 AM by Tfrank59 » Logged
-Tom
WintrSol
Florissant, MO
« Reply #4 on: March 14, 2016, 09:28:32 AM »
It is called a 'sprag clutch", and I suspect it is what is failing, too. If you have a mechanic's stethoscope, you can isolate the noise; start at the back of the engine, near the main clutch slave. As noted, a length of tubing, like fuel line, will work; even better if you put a metal object in the end you will be touching to the casings, as it will narrow the search better.
« Reply #5 on: March 14, 2016, 07:04:56 PM »
I'm thinking the tensioner pulleys on the timing belts.
We'll need to wait on where the noise is coming from.
dancnman
Houston, Texas
« Reply #6 on: March 16, 2016, 02:22:13 PM »
The best i can determine, the noise is coming from the alternator area, only more to the center and behind it. It is not the alternator though.
« Reply #7 on: March 16, 2016, 02:35:59 PM »
I recently had the nut come loose on the alt. drive. I wouldn't describe the noise as grinding but it might be worth a look.
Steel cowboy
Spring Hill, Fl.
« Reply #8 on: March 16, 2016, 06:10:49 PM »
Could be the alternator bearings. Or do you have chrome cover over the tranny, could be a loose bolt.
2001 black interstate
2003 Jupiter Orange wing
pancho
Bonanza Arkansas
« Reply #9 on: March 16, 2016, 06:25:10 PM »
I had my starter button sticking for awhile and found myself riding around with the starting spinning, once for thirty miles,, not grinding, just running,, whirring,, but something to look at and rule out.
dancnman
Houston, Texas
« Reply #10 on: March 20, 2016, 10:16:06 AM »
Well, whatever it is, I am going to pull the engine and find it. Can't have a problem just waiting to happen.
« Reply #11 on: March 20, 2016, 10:39:08 AM »
That sounds like a lot of work, that might not be required.
You need the engine running to figure it out. Unless you have all the good equipment to pull the motor and work on it in a shop.
I would be working on that cold engine making noise, and starting with a stethoscope, localize where the noise is coming from.
You can pull the alt, starter, and the timing belt tensioners pulleys, while the engine is in the bike.
« Reply #12 on: March 20, 2016, 10:39:32 AM »
can't be the engine needs to be pulled to find the problem I wouldn't think. Shocked
dancnman
Houston, Texas
« Reply #13 on: March 20, 2016, 10:44:43 AM »
Well the thing is, I bought another low mileage engine that I am going to replace it with. Then fix the other one and sell it.
« Reply #14 on: March 20, 2016, 11:42:50 AM »
Well... now we have the whole story...  cooldude
I used to rebuild and run VW air cooled engines on a tire, to test them before putting back into the car.
