April 29, 2026, 08:44:11 PM *
Author Topic: larger mirrors with integrated turn LED  (Read 3255 times)
spirit rider
« on: March 14, 2016, 07:28:13 AM »
Hi,
Did any of you guys tried to install these?
http://www.ebay.com/itm/Motorcycle-Cruiser-LED-Turn-Signal-Rearview-Mirrors-Universal-8-10mm-Smoke-Lens-/161722746985?fits=Year%3A2014|Make%3AHonda|Model%3AValkyrie+1800&hash=item25a76d4869:g:CrcAAOSwmmxW1koD&vxp=mtr
haven't bought them yet but I wonder if they be easy to install/connect
I always like more visibility and it happened that I forgot to switch off the turn light for few mns... (not going to get better with age, as I now hit the horn instead of the turn..Sad something might be reversed from the F6B)
thanks
dans2014
« Reply #1 on: March 14, 2016, 07:54:25 AM »
 Sad As I understand it, these won't work with the Valkyrie's electrical. I bought them for my Suzuki Bandit for the same reason, people and ME can see them blinking. On the other post-mirrors, I've posted the ebay item I put on mine. taller and wider, now I see better behind me
Dan's 2014 Valkyrie
dinosnake
« Reply #2 on: March 14, 2016, 01:29:38 PM »
I would / should probably tell you not to try - getting to the turn signal wiring at the forks is a nightmare (don't ask me how I know  Undecided ) .  Unless the service manual has a better way than disassembling most of the front end, plus the signal & voltage interface, IMHO just do yourself the favor and walk away from the idea.
Kidd
Sedona
« Reply #3 on: March 14, 2016, 02:35:21 PM »
Why not access wires at turn signal , and not at forks
« Reply #4 on: March 14, 2016, 02:46:16 PM »
The problem is not only the connections but the fact that the every bulb on the Valk is led with a controller under the seat and the voltages vary.
dinosnake
« Reply #5 on: March 14, 2016, 05:10:11 PM »
Yep, that's just about the only convenient area to do it in.  But note that the wires come in from the headstock area in a downward pointing position, where they then hide / shield the (small, round multipin) connector inside a [downward] facing vinyl weather sleeve.  The wires then loop upwards and through the fork covers and finally into the signal proper.
The front turn signals are 2 wires only regardless of the fact that they are multi-unit LED's, so it may be possible to work with them.  I didn't do a voltage test, sorry.
« Last Edit: March 14, 2016, 06:43:57 PM by dinosnake » Logged
spirit rider
« Reply #6 on: March 15, 2016, 06:51:11 AM »
waow, great answers! appreciate that.
so I'm "slowing" the idea as advised Smiley and I'll try to run some Voltage test ...
however I have no knowledge regarding LED...I guess I shouldn't try to wire from the connector (unless I manage to get a 12V on it), but rather find a way to go to the controller (if I manage to do that)...
thanks again
Stanc770
« Reply #7 on: March 25, 2016, 10:17:44 AM »
Go to the "Turn signals and Admore lighting" thread on the 1800 tech board. This issue you are facing is essentially the same problem. You WILL NOT get the desired results going in the direction you are headed.
Moofner is in contact with Admore for a solution for this issue. Some of us have the SOCAL lights with turn signals and have been seeking a way to make them work so, Moofner took ownership of the project and may have an answer soon.
Hate to sound so negative but many tries and hours have been expended in this matter and I am trying to give you the benefit of those experiences.
« Last Edit: March 25, 2016, 09:34:52 PM by Stanc770 » Logged
Moofner
Colorado Springs, CO
« Reply #8 on: March 25, 2016, 11:07:42 AM »
As Stanc said, I'm working on it. Even if it works, you will have to run a set of wires from under the seat. As far as I can tell, the only safe place to tap into the harness is POST ECU (aka the wire bundle going to the rear).
2003 Valkyrie "Ricky's Bike"
2014 Valkyrie "The Gypsy Bride"
