Kidd
« on: March 14, 2016, 02:53:37 PM » |
Rode my bike 60 miles , then installed the OEM tall shield , then later noticed the awful awful sound . I am thinking the shield echos it back at me . Maybe that's just the nature of the beast .
It's too much for me , at times .
I may remove the shield and see how it is then , for comparison
Anyone else having this problem ???
Kidd
« Reply #1 on: March 14, 2016, 03:30:14 PM » |
I didn't put up with the straight up-and-down OEM shield long enough to notice that... there's numerous ways to tilt it, the easiest is adding a little bit to the bracket, you could search or maybe someone will speak up... maybe tilting it will help... I modded my OEM shield a not-so-easy way, and it is awesome now...  -Mike
Kidd
« Reply #2 on: March 14, 2016, 03:46:50 PM » |
Are you meaning , you did notice the noise as I did ?
I have thought of adding a lower bracket to push out forward the bottom , allowing the top to tilt back some
« Reply #3 on: March 14, 2016, 04:47:08 PM » |
Can you describe the awful sound, I have not noticed anything I would describe as awful. The only sound I can remotely think of is the whine at idle and a bit above. This I believe is the alternator and wings do it also. I have the OEM tall windshield and have almost 8k miles on the bike and in the beginning it made some noises but they have quieted down. Now on the highway all I hear is the hum of the engine.
« Reply #6 on: March 15, 2016, 04:29:19 AM » |
One thing I really do like are the black wheel and spokes , never have to clean them You never have to clean anything...  these black wheels get plenty nasty, and if you have saddlebags, they're real hard to clean... hard to even get to the valve stem... painting aluminum wheels black seems like such a bad idea to me... I had to repaint mine last time I changed the tire... -Mike
dans2014
« Reply #7 on: March 16, 2016, 05:04:59 PM » |
 I prefer chrome polished wheels or aluminum anyday to black but I'm old fashioned cause black seems to be in so I put up with it!
Dan's 2014 Valkyrie
Kidd
« Reply #8 on: March 25, 2016, 08:18:04 AM » |
Oddly , most of the noise is from my full face helmet , some how captures the noise inside . Using my 3/4 face helmet with plastic shield is much less noisy , when I raise the plastic shield , even less . So, that awful whine type noise is amplified inside of my helmet
Anyone else notice this helmet oddity ?
« Reply #9 on: March 25, 2016, 09:20:44 AM » |
Everyone with riding experience with all helmet styles has noticed this. You should try a good DOT half without your ears covered. You may want soft plugs to protect from wind damage, but the noise (drone) you speak of will disappear, unless you run loud pipes (on purpose). I personally recommend the Scorpion (for those with oblong, as opposed to round heads) http://www.motorcyclegear.com/street/helmets_and_eyewear/open_face/scorpion/exo_c110_helmet.html
Kidd
« Reply #10 on: March 25, 2016, 09:40:05 AM » |
I have owned many bikes , never had this problem . Thank you for your response Half helmet would make me feel unprotected , looks funny too Oddly , most of the noise is from my full face helmet , some how captures the noise inside . Using my 3/4 face helmet with plastic shield is much less noisy , when I raise the plastic shield , even less . So, that awful whine type noise is amplified inside of my helmet
« Reply #11 on: March 25, 2016, 10:01:43 AM » |
Kidd... I've been thinking about what you said, and now I notice it too, thanks  I notice it more when gently rolling through the back roads and less when going faster, I also noticed this with my old Valkyrie when it had the triple tips on it, less so with the current setup. I think ear plugs are probably our only option... -Mike
goldstar903
« Reply #12 on: March 25, 2016, 06:29:57 PM » |
Seems to happen between, 2000 and 3000 rpm. Stay below or above and you should be good to go.
I love to go fast, but my wallet doesn't! Maybe I should leave my wallet home!
Kidd
« Reply #13 on: March 26, 2016, 08:18:51 AM » |
Kidd... I've been thinking about what you said, and now I notice it too, thanks  Maybe a good thing and maybe a bad thing that you now notice 10 years ago , reading a motorcycle forum , I learned about helmet buffeting , it never bothered me before , but , the buffeting started that day , that's when I noticed I had buffeting and then it started to bother me . ever since then , it was my fixation to fix it when ever I had buffeting on every new motorcycle I had purchased . 'bout the noise/whine , around 60 , give or take , with at lease some load , it's loud . maybe mine is broken
AdrianR
« Reply #14 on: March 26, 2016, 10:14:22 AM » |
I don't experience any of this until around 100+mph and then my helmet starts bouncing around...blurring my vision..sucks... I have a much shorter windshield..the key I believe is finding a windshield that is just the right height...and this is dependent on the individual rider... Keeps my speeds under 100mph...which in the end, is probably a good thing...
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #15 on: March 26, 2016, 10:22:36 AM » |
I also experience a very slight drone at 60mph however it is only a small mph window and on a 1-10 bother scale it is a 2. I have a Shoei GT Air full face. I want to try a open helmet especially seeing it is 86° here in Florida already  but I feel funny not having a full face.
goldstar903
« Reply #16 on: March 26, 2016, 10:37:08 AM » |
_Sheffjs_
Sarasota FL
« Reply #17 on: March 26, 2016, 10:39:50 AM » |
yipes! And what would happen on those times I am pushing the honda's limiter. I don't want to think about it.
Moofner
« Reply #18 on: March 26, 2016, 11:42:07 AM » |
I decided to pass my buddy off in his Challenger when we were leaving work and I was on the Valk. Left him in the dust (no surprise). He caught up to me, then wanted to do a 60+ MPH throttle stomp.
I didn't know I was doing 115 until I realized I was cold. I must have chosen the right windscreen cause it didn't feel like doing over 100.
The right windscreen makes all the difference.
2003 Valkyrie "Ricky's Bike" 2014 Valkyrie "The Gypsy Bride"
Kidd
« Reply #19 on: March 26, 2016, 11:43:16 AM » |
In Az, S man , you'd be going to jail is you were pushing the limiter . 125mph  yipes! And what would happen on those times I am pushing the honda's limiter. I don't want to think about it.
Kidd
« Reply #20 on: March 26, 2016, 11:44:33 AM » |
and , what windscreen do you have ? I decided to pass my buddy off in his Challenger when we were leaving work and I was on the Valk. Left him in the dust (no surprise). He caught up to me, then wanted to do a 60+ MPH throttle stomp.
Kidd
« Reply #21 on: March 26, 2016, 11:46:30 AM » |
wow , g man , would never have thought you'd have it in ya to go over the speed limit
goldstar903
« Reply #22 on: March 26, 2016, 01:07:41 PM » |
Where would you get that impression, K-man? I have an 87' Kawi ZX-750R (Muzzy Motor, RWHP, 125) top speed 157 (on speedometer) and a 04' Kawi ZX-10R (motor built for race, RWHP, 181), top speed 178 (GPS) They would go faster if I didn't weigh 278lb.  I love to go fast! My wallet doesn't!!  Maybe I should leave my wallet home?
Kidd
« Reply #23 on: March 26, 2016, 01:14:09 PM » |
So , you like kawa's My first big bike was a 1975 Mach 3 Kawa , 3 cylinder , 2 cycle , that was very fast bike . Got it from a bike magazine that tested and published articles about new bikes
goldstar903
« Reply #24 on: March 26, 2016, 02:58:14 PM » |
Oh yeah! The H1, 500cc of craziness! Too bad they outlawed the two stroke street bikes! The 750 (H2) was crazy too!
Kidd
« Reply #25 on: March 26, 2016, 03:01:25 PM » |
I got to thinkin' , over the last 18 months I have received 3 speeding tickets , 2 in my car , 1 on my BMW. Cost me about $700 , maybe more , that's with online school added , nothing going to insurance
goldstar903
« Reply #26 on: March 26, 2016, 03:15:15 PM » |
« Last Edit: March 26, 2016, 03:17:03 PM by goldstar903 »
Kidd
« Reply #27 on: March 26, 2016, 03:39:08 PM » |
something like that here in Az. 1 of my tickets was on I40 in Ca , almost made it to the Az line . other 2 were in Az , here in Verde Valley . One was in Jerome where they fine you a lot ($275for going 32 in a 20mph ) and don't send anything to Ins , they are just collecting revenue for the city Now I know it's okay to speed in Jerome knowing I will only pay a fine and nothing more  man oh man , there's a lot of cops out today , Easter weekend
Adirondack Bill
« Reply #28 on: March 29, 2016, 12:57:09 PM » |
Kidd- You are bringing back some great memories. My first street bike was also a kawi 2- stoke. I owned the S3A-- 400 cc triple. That bike was super quick, I usually beat my brother on his 1973 Z-1-900 in the 1/8th mile. Usta do some great wheelies with it also.
