February 11, 2026, 07:01:14 PM *
Pages: 1 [2]   Go Down
Author Topic: crack in block?  (Read 4220 times)
Tfrank59
'98 Tourer
Western Washington
« Reply #40 on: March 22, 2016, 07:06:09 PM »
Nice looking job and a great price!  I was wondering about the pull direction of the weld--good thinking on his part to run it as he did.  Also nice that you didn't need anything special with the threads, eh?  just screw the thing in there and ride! cooldude
-Tom
« Reply #41 on: March 22, 2016, 07:06:43 PM »
Well I had the crack repaired today and no sign of any leaks. The welder started at the top of the crack and worked his way down. He said doing this actually pulled the crack tighter as he made his way to the drain plug. He thought overall it went very well. The porous block casting with air pockets created holes he had to fill along the way. I put the bike back together and took it out for a test  ridewith no signs of leaks. The weld is a little bulky but I am thrilled. He asked for $45, I gladly gave him $60. Very glad to be back on the road again, at least after tomorrows snow storm. cooldude cooldude cooldude
Man that worked out awesome ! I had my doubts. I think it looks fine.  cooldude
« Reply #42 on: March 22, 2016, 08:12:18 PM »
My concern was you could clean it all you wanted to, but there is still oil inside the block leaking out. I figure the heat of the weld keep new oil away.
Did you need to do anything with the thread, or just screw in the plug again?
I would keep the big weld like it is, but if you want, you could always grind it flush to the block to make it look pretty again.
« Reply #43 on: March 22, 2016, 08:18:46 PM »
Wow, nice job cooldude
Cheap too Smiley
I'd leave it alone, just look at it to remind me to be easy with the wrench. Roll Eyes
pancho
Bonanza Arkansas
« Reply #44 on: March 22, 2016, 08:19:47 PM »
Wow, that guy knows his craft........   looks great    ......
"The porous block casting with air pockets created holes he had to fill along the way."  just that would have lesser welders puckering up if it was someone elses bike.
Great outcome Dan,, I bet  Undecided you feel better now cooldude
Tfrank59
'98 Tourer
Western Washington
« Reply #45 on: March 22, 2016, 09:01:10 PM »
"...if you want, you could always grind it flush to the block to make it look pretty again."
[/quote]
I think it would be best just to leave that alone, and hope that there's no porosity for oil to seep through and that there wouldn't be any further problems. As for the cosmetics, well it is what it is.
-Tom
ValkISDan
Forest Lake, MN
« Reply #46 on: March 23, 2016, 05:58:07 AM »
The welding was done with the drain plug installed so no work would be needed after he finished. The weld actually filled flush to the crush washer surface so you couldn't see the crack with the plug out. I will eventually break out a dremel tool and do some minor touch up.
« Reply #47 on: March 23, 2016, 06:28:11 AM »
Glad it worked.  If all is well, I would leave it.  No one is going to see it,
« Reply #48 on: March 23, 2016, 06:33:18 AM »
 cooldude  Looks good.
Tfrank59
'98 Tourer
Western Washington
« Reply #49 on: March 23, 2016, 08:41:24 AM »
As far as using a Dremel and dressing up the appearance – I wouldn't do it just because you could open up a path for oil seepage, since the welder was fighting porosity as he welded. I think you're better off not touching anything at this point.  Oil could start seeping out at some point, especially in the summer months when things get really hot, so the jury is still out on this repair and you're better off just waiting and keeping an eye on it IMO.
-Tom
pancho
Bonanza Arkansas
« Reply #50 on: March 23, 2016, 09:02:57 AM »
The repair is great and will never give a problem again, leave it alone Dan.
« Reply #51 on: March 23, 2016, 09:07:55 AM »
+1  you already dodged one bullet. No sense reloading the gun. It looks fine  coolsmiley
Firefighter
Harlingen, Texas
« Reply #52 on: March 23, 2016, 09:55:51 AM »
What did you take apart? Did you lay the bike on its side? Looks great to me! I would order a new oil drain bolt and seal for the next time.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
« Reply #53 on: March 23, 2016, 02:16:04 PM »
The lesson to be learned here involves not overusing the crush washer.  The book says a new one every time.  I tend to cheat on that a few but be sure there's still aluminum to be crushed.
Fortunately I learned that lesson on a Magna and not on my Valkyrie.
ValkISDan
Forest Lake, MN
« Reply #54 on: March 23, 2016, 05:36:31 PM »
You guys are right I probably won't touch this anymore. From two feet away you couldn't tell its been repaired. Thanks for all the help and support as usual.  cooldude
Tfrank59
'98 Tourer
Western Washington
« Reply #55 on: March 23, 2016, 06:30:14 PM »
Way to go. And let us know if something does go south on the repair. Ride safe. cooldude
-Tom
Savago
Brentwood - CA
« Reply #56 on: March 23, 2016, 07:43:02 PM »
+1 to leave it alone.
Savago
Tfrank59
'98 Tourer
Western Washington
« Reply #57 on: March 23, 2016, 08:29:31 PM »
"Very glad to be back on the road again, at least after tomorrows snow storm."
Dan, saw the forecast for MN tomorrow--sucks!  Guess you won't be checking out this repair for a few days...weeks Grin
« Last Edit: March 23, 2016, 08:31:03 PM by Tfrank59 » Logged
-Tom
peter
Bethesda, Maryland
« Reply #58 on: March 25, 2016, 06:28:52 AM »
Good work - you dodged a bullet there, or a cannon ball.
'98 Valk
'56 BSA
'04 Ducati
bohica66
« Reply #59 on: March 26, 2016, 05:15:02 PM »
I put a fumoto valve on a 6.7 cummins after finding out what happens when you pull the drain plug on 3 gallons of black sooty oil. That used diesel oil is really hard to clean up and any clothing it gets on is ruined. The fumoto valve is brass and opens with a small spring loaded handle which I drilled a small hole in and safety wired, just in case some brush might be able to move it, which is highly doubtful, or somebody might see it and open it. Safety wire won't stop someone, but might deter them. No more messing with crush washers or drain plugs.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #60 on: March 26, 2016, 07:18:57 PM »
Looks great and a good price.
Happy Easter!
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
« Reply #61 on: March 27, 2016, 07:43:40 AM »
Have on my 7.3 PowerStroke.  used a small hose clamp over the end, to prevent unauthorized opening.
Scottrtho
« Reply #62 on: April 11, 2016, 10:49:49 PM »
Here is another solution to changing your oil without having to remove the drain plug. Very popular among car Geeks here in California. They work great. Hold about 6 or 7 quarts.
http://www.northerntool.com/shop/tools/product_390306_390306?cm_mmc=Google-pla&utm_source=Google_PLA&utm_medium=Fuel%20Transfer%20%2B%20Lubrication%20%3E%20Oil%20Extractors&utm_campaign=LiquiVac&utm_content=33226&gclid=CjwKEAjwlq24BRDMjdK7g8mD6BASJABBl8n3LKMmQOl0W4ekd3TQpWzpu9tVWm5LbMZ4mWtB7Ec5UhoCmcfw_wcB
Pages: 1 [2]   Go Up
