November 27, 2025, 01:37:11 AM *
Author Topic: It's electric ( fixed )  (Read 1112 times)
larue
Clermont,FL
« on: March 18, 2016, 04:41:55 PM »
After powder coating the cobra light bar on the tourer and everything put back together blinkers and driving lights all work except I ran into one problem, when I push left turn signal the rear left works however the left front go out along with both spot lights, the right turn signal works fine and driving lights stay lit. When I cancelled the turn signals all light come on as they should. Spot lights and front turn signals. Any help is appreciated . Thank you
« Last Edit: March 23, 2016, 01:20:38 PM by larue » Logged
« Reply #1 on: March 18, 2016, 05:35:16 PM »
Hey Rue.....you know where I live buddy. I'm cheap too, just ask Rita.   Grin
Seriously, we can run it in between the 1200 and the Valk. Lots of room.
WintrSol
Florissant, MO
« Reply #2 on: March 18, 2016, 06:44:55 PM »
The turn signal switch removes power from the running light filament on the selected side, at the same time connecting the flasher to the signal filament, so the connection from the switch, through the orange wire, to the bulb is suspect. Why the other lights would go out is a mystery, unless you powered them from the left running light switched power, which is orange/white, instead of the lighting power wire, which is brown.
TJ
Lake Placid , Fl.
« Reply #3 on: March 18, 2016, 08:16:24 PM »
It's a ground problem Rue...
larue
Clermont,FL
« Reply #4 on: March 19, 2016, 05:55:05 PM »
hey thanks john no rush yet to fix it but will get to it soon as I get a break from work, if I fail I may just show up at your door  Smiley
« Reply #5 on: March 19, 2016, 06:59:07 PM »
That's fine, call first just to make sure I'll be home.....or not taking a nap.  Grin
larue
Clermont,FL
« Reply #6 on: March 23, 2016, 01:24:28 PM »
My neighbor walked in to my garage and told what was happening he opened the head light bucket after testing few wires he took a 5" long wire laying around tapped it in between a black wire to a brown wire in there and wala everything works perfect. Guess I got lucky
. Thanks for all the input everyone.
« Reply #7 on: March 23, 2016, 01:29:27 PM »
Man I wish I had a neighbor like that  cooldude
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #8 on: March 23, 2016, 01:35:24 PM »
Me too  cooldude
