BonS
« on: March 30, 2016, 09:24:16 AM » |
Well, my go-to motorcycle dealer no longer mounts car tires. They had one of their technicians hurt while mounting one and that was that. I'm thinking about getting a Harbor Freight tool and doing it myself. Any darksiders mount their own CT using the Harbor Freight tool? Anyone in the KC, MO area that knows of a shop that will do it?
matt
« Reply #1 on: March 30, 2016, 11:06:08 AM » |
Hey bons, I work a a car repair/ tire business and the machines we have will mount car tire on motorcycle wheel. Check out some tire shops see if they will do it for you
jdp
« Reply #2 on: March 30, 2016, 11:16:48 AM » |
Most small independent shops will mount it for you
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #3 on: March 30, 2016, 11:18:16 AM » |
I go to the used tire shop in my town to have them mounted. I started out by telling them it was a trailer rim but after while they called BS on me but still install them.
jdp
« Reply #4 on: March 30, 2016, 11:19:37 AM » |
I have a regular tire mounting machine but use to have a harbor freight one, I welded and mounted plastic rim holders onto it and had no trouble at all, it will just work you when mounting mc tires but the car tires just slip right on
mustang071965
those that dare, Succeed.
monticello Ar
« Reply #5 on: March 30, 2016, 11:38:53 AM » |
do mine and dads, i have the tc-mcatvm changer from JCM automotive Equipment. its heavy duty and no need for mods on the grips. there hooked and already plastic coated. it will do from 4'' to a 21'' rim.mounted it on a pallet and its stable and no effort to remove and put on a CT or motorcycle tire.
BonS
« Reply #6 on: March 30, 2016, 02:40:07 PM » |
I checked out the JCM changer and bought one today. It looks more substantial that the HF model and comes with nylon/delrin to protect the rims. I'll use a friends HF unit to do my tire change, that I need right away, and get some familiar with the procedure. For safety's sake I'm going to use a screw-on air chuck and stand safely away when filling the tire the first time.
« Reply #7 on: March 30, 2016, 05:07:20 PM » |
A warmed tire should also be easier to mount. I don't know if you're looking at a powered unit, or a manual one.
art
Grants Pass,Or
Grants Pass,Or
« Reply #8 on: March 30, 2016, 08:20:21 PM » |
I've done all my tire changes with tire irons for 12 years. That's about 18 tires and half were C/T s
Firefighter
« Reply #9 on: March 31, 2016, 04:27:41 AM » |
I used to change a lot of boat trailer and some car tires with hand tools but when I tried changing the Valkyrie tires I seem to always scratch the wheels. I was use to steel wheels, didn't have to worry about scratching wheels. Guess I don't have the correct tools to change my Interstate with out scratching, so I have paid a local guy to mount them, but not sure for how much longer he will be in buisness.
2000 Valkyrie Interstate, Black/Red 2006 Honda Sabre 1100 2013 Honda Spirit 750 2002 Honda Rebel 250 1978 Honda 750
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« Reply #10 on: March 31, 2016, 04:38:45 AM » |
I was in the same situation and found a small shop and he initially said no and we got to talking and the reason for his no, he had never done one...so he said let's take a look and his main concern was clearance between the table and the rim...it cleared and he pit it on and aired it up and didnt charge me anything, just gave me his card ank asked that I check his tire prices before ordering tires....very cool
RDKLL
Mesa, AZ
« Reply #11 on: March 31, 2016, 04:40:14 AM » |
To anybody running a 130/100 or 100/90 h4 bulb....what brand? I will be ordering Bon's SMart Switch so I am assuming I will not need a relay in addition, correct. Thanks in advance
« Reply #12 on: March 31, 2016, 05:06:07 AM » |
I used a small tire independent shop . Had to take rime and tire to them.
« Reply #13 on: March 31, 2016, 05:32:04 AM » |
I have a 100/90 in my standard. I got it at Napa. I think it was a generic store brand, it did say on the packaging only legal for off road use. And yes as I understand it you won't need a relay with his SmartSwitch.
mustang071965
monticello Ar
« Reply #14 on: March 31, 2016, 05:47:36 AM » |
also check out the Wikco mount demount bar, wikocind.com. i bought it to go along with my tire changer. it is made from a solid bar of metal very strong, it has the no scratch protectors on both ends. they are replaceable in case one wears out. love it. part# is 100-14c.
BonS
« Reply #15 on: March 31, 2016, 05:55:59 AM » |
I have a 100/90 in my standard. I got it at Napa. I think it was a generic store brand, it did say on the packaging only legal for off road use. And yes as I understand it you won't need a relay with his SmartSwitch.  That's correct. All you'll need is the SmartSwitch. The single headlight SmartSwitch comes standard with a 10 amp fuse. The dual headlight SmartSwitch comes with a 15 amp fuse. You can safely bump up the 10 amp fuse to 15 and the 15 amp fuse to 20. The 100 watt bulb draws around 7.6 amps so you're good to go. A 130 bulb draws right at 10 amps so I'd bump up the fuse to 15 amps if you do that.
wiggydotcom
Yorkville, Illinois
« Reply #16 on: March 31, 2016, 04:01:52 PM » |
I used my Harbor Freight unit to change out numerous motorcycle tires and my Yoko Avid Envigor car tire a couple years back. I did enhance the unit with mojoblocks and a mojolever which was a big improvement over the stock bar.
The tip about warming the tire in the sun is a good one.
I hope you have good success and like the JCM changer also.
VRCC #10177 VRCCDS #239
Led
« Reply #17 on: April 01, 2016, 03:14:02 PM » |
I used to work in the Tire and Lube section of Wally's. I punched out for the day, and brought my "darkside project" in, off the clock. My Manager freaked out, wondering what I was doing....... I am NOT sure where I can have one mounted anymore, myself. I LOVE that I got away with mounting my own, the first time, with professional equipment!!! My Manager was young enough to be my Son.......that is why He let me slide on that one.......
BonS
« Reply #18 on: April 01, 2016, 07:50:18 PM » |
Thanks all! I have a NoMar bar on order along with the YellowThing. The changer that I have on order has some type of wheel protection. I don't think its nylon or delrin so we'll see. If I don't like it then it'll be my first mod. I've watched a few YouTube videos so I'm the Expert now.  Wish me luck!
wiggydotcom
Yorkville, Illinois
« Reply #19 on: April 02, 2016, 02:56:53 PM » |
One more thing. I'm sure you've noticed if you watched a lot of videos but lube is your friend. It makes the job a lot easier if your get the tire and rim lubed generously. And no wisecracks.
Bone
« Reply #20 on: April 02, 2016, 04:47:26 PM » |
My independent bike shop has closed. The owner changed all of my tubeless tires and 3 CT for me. I bought myself a H.F. changer last fall and a new front tire. Haven't tried the machine yet but last week bought a gallon of tire lube at Advanced Auto. I'm ready to wrestle
BonS
« Reply #21 on: April 02, 2016, 06:57:30 PM » |
I went shopping for tire lube and found nothing at several auto parts stores. I was hoping to find a small tub or bottle but not a lifetime supply - unless it has alternative uses! The guy at Advanced Auto looked up something and he came up with "Discontinued". I read that antifreeze is a good lubricant and dries slowly so I think I'll be using that. I used beads for balancing and don't want sticky residue inside the tire. I'll be doing a CT on the rear wheel and an Avon on the front.
rhinor61
« Reply #22 on: April 02, 2016, 08:24:55 PM » |
Tire lube is to be used on the inside not the bead side of the tire as per the guys at NoMar.
I have their lube.. TIRE LUBE PASTE [1 PINT JAR]
otherwise, you could spin the tire off the rim, which I have done after the boys at the honda shop did my tire install.. No more, I do all my own tires and services.
J.
John
Northern California 1998 Valkyrie Tourer Black/jade VRCC #28001
mark81
« Reply #23 on: April 02, 2016, 10:53:21 PM » |
Dawn dish soap or Murphys oil soap are good mounting lubricants that will not deteriorate the rubber
1997 Honda Valkyrie 1981 Honda CB750 Custom
Bone
« Reply #24 on: April 03, 2016, 02:05:59 AM » |
Don't want to create a dangerous problem I have a large bottle of Dawn.
I'll go with what is known to work thanks.
BonS
« Reply #25 on: April 03, 2016, 05:51:38 AM » |
Okay, change of plan. Michelin says "Vegetable oil soaps or animal oil soaps, in solution, are the preferred materials for use as bead lubricants. Never use antifreeze, gasoline, ether, silicones, or any petroleum based lubricants. Never dilute lubricants beyond that recommended by the manufacturer since this may have a harmful effect on the tire and wheel/rim." Here's a link to their advice. http://www.michelintruck.com/assets/pdf/bulletins/TB_Lubricant_MX_Truck_Tires.pdfI noticed that Murphy's soap is a vegetable oil soap but it also contains propylene glycol which is antifreeze. I guess I'll keep looking for a lube! Or maybe it'll just be Dawn.
« Reply #26 on: April 03, 2016, 07:28:28 AM » |
I've used Dawn and other dishwashing soaps. The problem is mixing them with water to the right consistency. Lately I've been using the foaming hand soap. The kind that comes out of the dispenser in a foam. I just apply straight onto the tire and it seems to be the right consistency. I haven't had any problems with the beads, but I don't put mass quantities on.
« Reply #27 on: April 03, 2016, 08:41:27 AM » |
Use Murphy's oil soap and water.
« Last Edit: April 03, 2016, 08:43:19 AM by Skinhead »
mark81
« Reply #28 on: April 05, 2016, 08:25:06 PM » |
I think they were referring to ethylene glycol which is the most common antifreeze. Propylene glycol can also be used as an engine antifreeze but is more commonly used to winterize boats and RV's. It is also used as a food preservative
da prez
« Reply #29 on: April 06, 2016, 05:04:46 AM » |
Half dawn and half water. Brush on until you have a foam appear. When done , tire can be rinsed off easily . There is a bead up wax soap made for tire mounting. I can't think of the name now. My coffee isn't fully working as of yet. I have used both for years and still do at the HD shop where I work.
Bonn , I still have not gotten any more of the info on the HD situation I mentioned . Maybe a talker only.
da.prez
