February 11, 2026, 08:39:16 PM *
Author Topic: Help hose routing/connecting - reviving old girl  (Read 3678 times)
s4rhoolie
« on: April 02, 2016, 04:26:28 PM »
Hope someone can help.....(this could be also "introduction" thread)
I purchased a '98 Valk and saved it from going to a golf cart custom installation. If you ask me, this thing of beauty had to go back to normal and i have to give it a shot in restoring it. Got it as a (quite a few) basket case and i'm at the point where i need to start connecting hoses to a carbs, airbox and fuel. I got service manual (digital version) but it's not 100% clear where few hoses from those intake manifolds are going and another one (i think it's a vent hose) from a gas tank...It's a 98 GL1500 CT
Looking forward to start her up soon, it's cleaned inside, valves adjusted, ready to rock....any info/tips/help appreciated...THANKS
Bone
« Reply #1 on: April 02, 2016, 04:54:11 PM »
Welcome to the group. You've just bought a wonderful bike I also own a 98 CT I bought with 22k miles on the clock.
Have you noticed the links above ? Shoptalk will answer many questions for you.
« Reply #2 on: April 02, 2016, 04:55:45 PM »
Hoolie, go to your profile and add where you're located; city, state, etc.  There's usually someone nearby that can lend a hand from their own experience. As for where all the hoses go, since I've desmogged my ride I frankly don't remember where they all go. Hopefully someone else with chime in, it's not real involved but I found the hard copy of the manual easier to use.  cooldude
Ramie
2001 I/S St. Michael MN
« Reply #3 on: April 02, 2016, 06:11:59 PM »
Welcome, if it hasn't been done yet look at doing a desmog, eliminates a lot of hoses and a lot of potential vacuum leak problems.  https://sites.google.com/site/valkparts/ sells a stealth desmog kit.
You can find an online manual here.
http://valkyrienorway.com/download.html
« Reply #4 on: April 02, 2016, 08:13:57 PM »
Welcome. I also always recommend a hard copy. I like the digital PDF for the computer and traveling, but nothing like the manual beside you at the bike.
I've not done something like that myself, but would also recommend a de-smog too. Search is always your friend. It's just hard sometimes knowing the right or best word to use.
I also like going to ebay, do a search for what you want, in this case an engine, and you can look over the different pictures and see what it looks like outside of the bike. I think that would help a lot.
big poppa pump
San Antonio, TX
« Reply #5 on: April 03, 2016, 09:13:16 AM »
Definitely do a de-smog, you will eliminate a lot of vacuum hoses down there. I even got rid of all the carb drain hoses on both my bikes. Never used them, probably never will!
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #6 on: April 03, 2016, 11:12:16 AM »
Same here. I figure if I ever need to drain the bowls I can hook a hose up one at a time.
Steel cowboy
Spring Hill, Fl.
« Reply #7 on: April 04, 2016, 11:07:06 AM »
If you go to google and type in Honda Valkyrie vacumm lines. You'll get a ton of pictures as to were they all go.
2001 black interstate
2003 Jupiter Orange wing
« Reply #8 on: April 04, 2016, 12:17:15 PM »
If you do the desmog, the only vacuum line you will need is from number 6 carb to the OEM  petcock. Also, one  of the lines to airbox would be eliminated. Redeye has what you need to do the desmog (see below ).  I wouldn't eliminate the carb drain tubes, you never know when you might want to empty your float chambers.?
My rides:
BobB
« Reply #9 on: April 04, 2016, 12:25:09 PM »
Welcome to the insanity.  I assume you are talking about vent and breather hoses as well as vacuum lines.  You need to enlist the direct aid of one of us nearby, not a Honda dealer, to help out.  There is a mess of hoses under the tank and I would not know where to begin.  I concur with the recommendation to do a desmog.
As the proud owner of a '98 Tourer, welcome...
« Last Edit: April 04, 2016, 12:40:44 PM by BobB » Logged
s4rhoolie
« Reply #10 on: April 08, 2016, 01:41:34 PM »
Wow! Thank you guys for all the replies! Kit ordered on-line, can't wait to install it...(printed service manual on the way also)
