February 11, 2026, 08:39:16 PM
Replacing Clutch Lever
Topic: Replacing Clutch Lever (Read 960 times)
dconstruct55
Phoenix AZ.
April 03, 2016, 01:14:00 PM »
Have a '99 standard that will not start with clutch in and in gear. Looked through old posts and at least one issue was clutch lever and bushing wear. The clutch lever rattles to the point that it is annoying when riding, so I thought that was a good place to start. Found a nice set of OEM levers on Craigslist, so I thought I would get at it. One problem, I am a carpenter NOT much of a mechanic. This project seems pretty straightforward, but I thought I would hit up the braintrust anyway. When I take the lever off, are springs and things going to start flying around? Any instructions from the forum?
Thank you,
Dcon
Re: Replacing Clutch Lever
April 03, 2016, 01:47:08 PM »
no spring's will fly. Just pay attention to the brass bushings and make sure everything goes back on the way it cam off. Put a very small amount of grease on the pivoting parts. Should take 5 minutes per lever
dconstruct55
Phoenix AZ.
April 03, 2016, 02:01:32 PM »
Of all the great minds on this forum, I was hoping that you would be the first to reply Chris. I am working on the bike outside, so I was a little afraid of having parts fly and not finding them again.
indybobm
Franklin, Indiana VRCC # 5258
April 03, 2016, 03:06:54 PM »
if you put your ear down by the clutch lever you should hear the switch click when the clutch lever is pulled in all of the way.
So many roads, so little time
VRCC # 5258
dconstruct55
Phoenix AZ.
April 03, 2016, 03:31:51 PM »
Thanks Indy,
I am about to go outside and start changing it out.
dconstruct55
Phoenix AZ.
April 03, 2016, 04:17:52 PM »
Ok done,
Old brass bushing in the original lever pretty worn. Changed it out and Valk started up in gear with clutch in. Chris was dead on, 5 minutes....
Thank you Chris and Indy
