February 11, 2026, 08:39:06 PM
fixing a few things
Topic: fixing a few things (Read 797 times)
mont
massachusetts
fixing a few things
April 07, 2016, 03:40:33 PM »
just got done replacing vacuum hoses and intake O-ring .. i might as well replace the fuel tank lines
everything going fine when i pull out the tank vent line ..about 6" long with a T connected to nothing and
3" more .. the question is .. doesn't it go all the way under the bike? and does anything connect to the T
also the driving lights are connected to the headlight bucket ( i don't use them after reading this forum)
was going to use the blue / white for trigger --- i have my Dan Marc switch on the acc. wire ... finding a lot of Mickey Mouse stuff on this bike i am slowly fixing.. Been riding all my life and built hot rods and this bike is quite a machine !!!!!
thank
MONT
Re: fixing a few things
April 07, 2016, 04:00:30 PM »
Yes it should be longer than 6" and end under the bike. Nothing hooks to the "T" it is a vacuum break.
mont
massachusetts
April 08, 2016, 05:02:36 AM »
ok thanks ..that what i thought ..what i should have asked was ...should the T be in that line
or just run a straight line under the bike ??
thanks
April 08, 2016, 08:29:14 AM »
Quote from: mont on April 08, 2016, 05:02:36 AM
thanks
Keep the T . If not in a heavy rain you could get blockage and no fuel.
