February 11, 2026, 08:39:07 PM *
Author Topic: H-3 Led replacement bulbs  (Read 910 times)
Mr.BubblesVRCCDS0008
« on: April 08, 2016, 06:53:27 AM »
 looking to purchase some LED replacement bulbs to replace the 35 watt H-3 bulbs in factory spotlights on an interstate. Don't know to much about the terms SMD, Creel, any help would be great.
« Reply #1 on: April 08, 2016, 07:40:00 AM »
I would be very interested in what you find. I've been wanting to do this for a while but haven't found anything.
big poppa pump
San Antonio, TX
« Reply #2 on: April 08, 2016, 08:43:14 AM »
http://www.amazon.com/OPT7%C2%AE-CREE-LED-Light-Bulbs/dp/B00SZK2C7Q
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
WintrSol
Florissant, MO
« Reply #3 on: April 08, 2016, 09:11:18 AM »
FWIW, SMD stands for Surface Mount Device, or soldered flat to a circuit board, instead of with contact pins. CREE is/was a manufacturer of very bright, SMD type LEDs, but, much like Xerox and Kleenex, has started to be used for any similar device, not always made by Cree. caveat emptor
« Reply #4 on: April 08, 2016, 11:06:22 AM »
Thanks bpp. Do you know if they fit in the stock pod light housing ?
« Reply #5 on: April 08, 2016, 01:03:33 PM »
Some of the ones I've looked at seem they might be to long to fit in the housing. I'm gonna pull one of mine aprt and see how much room is there. I did find a few that about the same size as the stock ones but gonna wait till I see what will fit.
