February 11, 2026, 07:01:13 PM *
Author Topic: Battery  (Read 1107 times)
rknef777
Lake Martin, Al.
« on: April 09, 2016, 01:21:56 PM »
Hey guys,   About gout my bike all complete.  Been a rough spring with back surgery and all but have recovered and rebuilt a lot of things on the bike.  Thanks to a lot of you and much patience.  Anyway couple of more questions opinions.  Want to replace battery. Mine will not hold charge very well
Anymore.  Too much draining it over ast few months.  Time to replace anyway.  Any suggestions.  Want the best battery i can get.  2nd question.  Anyone replace the lights on interstae trunk with leds, if so what did you use.  Thanks Rich.  See yall in WV.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #1 on: April 09, 2016, 02:56:09 PM »
The original Yuasa batteries that came in the Valks when new lasted 7-8 years, some even longer.  Get another from your Honda Dealer.  Make sure it is fully charged before putting into service.
Don't get a Yuasa from a battery "store".  It is Not the same.
States I Have Ridden In
big poppa pump
San Antonio, TX
« Reply #2 on: April 09, 2016, 03:03:38 PM »
I have switched over to a Deltran Battery Tender LiFePO4 battery on both my bikes. Absolutely no issues. Good cranking power and I never have to put it on a charger.
http://www.amazon.com/Battery-Tender-BTL14A240C-Lithium-Phosphate/dp/B00F9LPJ8S
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Gideon
Indianapolis, IN.
« Reply #3 on: April 09, 2016, 03:49:37 PM »
Last month I replaced my battery with a Battery Plus (X2-14 MADE BY DURACELL) sealed, maintenance free, high performance, gel-type. Has higher cranking amps than stock YUSA. I didn't have any problems, but after six years on the last one from Battery Plus, I thought it was time.  cooldude
« Reply #4 on: April 10, 2016, 06:06:56 AM »
Yuasa for me. Amazon sells them for $72.  cooldude
My rides:
« Reply #5 on: April 10, 2016, 07:32:19 AM »
Anyone replace the lights on interstate trunk with leds, if so what did you use.
There used to be a link that showed a how-to, with pictures, of a trunk light conversion to LEDs.  I believe the project was put together by Red Barber and Bill Gurney (Grumpy).
I went and found it, but it no longer works.
It involves a partial disassembly of the trunk, use of heat gun to disassemble the glued-together light sockets, install of small LED arrays in place of bulbs, wrapping the new assemblies in foam before putting them back in the trunk.
These were the LED arrays used in the project:   http://www.shop.braggengineering.com/product.sc?productId=3&categoryId=1
This is the non-working link (FWIW):    http://home.comcast.net/~red.barber/taillight.htm
This is a wiring diagram that may be useful:   http://www.rattlebars.com/mtz/istrunklights.html
ripper980
Beeton, Ontario, Canada
« Reply #6 on: April 10, 2016, 11:42:26 AM »
Yuasa  YTX14H-BS .. more cranking amps then YTX14-BS
ride to work, work to ride Smiley
