January 29, 2026, 04:46:31 PM *
Author Topic: Fuel sensor O-ring install? I'm stumped  (Read 1504 times)
Hellcat
Arlington, VA
« on: September 19, 2009, 02:21:22 PM »
I need to put a new O-ring at the fuel sensor where it mates up with the underside of the tank, but I don't see how I can get the fuel sensor out of the tank.
It's too big to come out of the hole any way that I see. There are a couple of tiny bolts to unscrew but there are several hard soldered points too. It won't go over the bottom mount that I can see - too big to stretch the o-ring.
Suggestions?
Joe Hummer
Arnold, MO
« Reply #1 on: September 19, 2009, 02:58:59 PM »
I will preface this with...I have never pulled my fuel level sensor...but...looking at the parts fiche...I would say it is a contortionists nightmare to get out.
Maybe looking at it will help you decide how it will come out.
http://fiche.ronayers.com/Index.cfm/Module/Main/TypeID/26/Type/Motorcycle/MakeID/1/Make/Honda/YearID/40/Year/1999/ModelID/6791/Model/GL1500CF/GroupID/289209/Group/FUEL_TANK
Joe
1999 Valkyrie Interstate
Hellcat
Arlington, VA
« Reply #2 on: September 19, 2009, 03:40:51 PM »
Well, there's no reason that should have helped me - I had looked at that fiche many times. But nonetheless, looking at it again, a light went on.
I could see the end of the sensor through the top tank hole (with the chrome piece removed), and I managed to slip the o-ring over it using some needle nose pliers, then worked it downward. It took some finger contortions and I wasn't sure I would be able to do it. It could have been a disaster given how clumsy I tend to be - dropping the o-ring into the tank was a real possibility, but it worked out.
Thanks!
