sinner
HC SVNT DRACONES
Canberra OZ
« on: April 10, 2016, 12:00:11 AM » |
Hi,I just checked the tyre pressures on my Valk. The little box thing that supports the valve is missing. Anyone know its official name so I can order a couple? Thanks Bob
98 Valk Tourer 83 CX650
Other than my Valk, my favourite pastime is turning beer into urine.
Bone
« Reply #1 on: April 10, 2016, 02:49:42 AM » |
HOLDER, RIM VALVE
42754-MN5-000
« Reply #2 on: April 10, 2016, 04:19:16 AM » |
Hi... Find a place to order something like this:  To avoid this:  The plastic OEM valve stems in Valkyries really are just a flat tire (or worse) waiting to happen... -Mike
bentwrench
« Reply #3 on: April 10, 2016, 05:37:41 AM » |
« Reply #4 on: April 10, 2016, 06:43:17 AM » |
Jake Wilson's where I got the picture, but the op's not in Kansas anymore  -Mike
Pete
« Reply #5 on: April 10, 2016, 08:17:42 AM » |
WintrSol
« Reply #6 on: April 10, 2016, 09:13:48 AM » |
Jake Wilson's where I got the picture, but the op's not in Kansas anymore  -Mike There's no place like home ... click ... there's no place like home ... click ... there's no place like home ... click
98 Honda Valkyrie GL1500CT Tourer Photo of my FIL Jack, in honor of his WWII service
bentwrench
« Reply #7 on: April 10, 2016, 04:07:15 PM » |
Jake Wilson's where I got the picture, but the op's not in Kansas anymore  -Mike There's no place like home ... click ... there's no place like home ... click ... there's no place like home ... click  Sorry. I missed that home address
sinner
HC SVNT DRACONES
Canberra OZ
« Reply #8 on: April 12, 2016, 03:01:19 AM » |
Thanks Guys.
I will check with my local Honda dealer.
Just had a look on Oz Ebay. $A30-40. inc Postage. (from US) Must be gold covered in plastic.
So, the metal valve stems don't need a plastic support?
Bob
« Last Edit: April 12, 2016, 03:09:01 AM by sinner »
Brian
« Reply #9 on: April 12, 2016, 03:37:11 AM » |
Thanks Guys.
That's right. The support holds the stem in place at a 90 degree angle all the time. Some have stated that at highway speeds the OEM rubber mounted stem will try to straighten out with the centrifugal force causing it rip off or just crack and leak. The OEM stems should be replaced periodically especially if using chemical cleaners on the rims. Just my two cents. I am using these $2 stems now with no problem. The OEM units will work well too if you keep the plastic holder on there. By a few and keep one in the tool kit. That's what I did. Ride safe.
Bob
« Reply #10 on: April 12, 2016, 09:48:25 AM » |
Bob
Bob (Brian?) is right. The full metal stems don't require the support, but his science is a bit flawed. Centrifugal force will cause the stem with the rubber middle to try to collapse. In my opinion the greatest risk to ruin is not centrifugal force but pressing an air nozzle or tire gauge against the stem. A torn rubber middle will crack and leak giving you a low to flat tire at the most unexpected and inconvenient time. I don't think anyone has ever seen one rip itself completely off at speed. Full metal stems don't have the problem.
john
« Reply #11 on: April 12, 2016, 11:06:41 AM » |
Bridgeport Angled Aluminum Valve Stem Motorcycle ...  and forget about it
vrcc # 19002
h13man
Indiana NW Central Flatlands
« Reply #12 on: April 12, 2016, 06:45:43 PM » |
Traveling w/o one regardless of construction of right angle valve core may result in flat tire. Been there and done that and I had a metal version. Look on Ebay for them. I bought a lot of 10 OEM core retainer for $20.
« Last Edit: April 12, 2016, 06:49:38 PM by h13man »
« Reply #13 on: April 12, 2016, 09:57:23 PM » |
You had a metal valve stem fail because you didn't have the keeper on it ?
8Track
« Reply #14 on: April 13, 2016, 12:07:08 AM » |
Can you replace the valve stems at home without taking the tyre off the rim?
« Reply #15 on: April 13, 2016, 04:15:58 AM » |
Yes, some have done it with the tire on the bike. I think it takes a couple big C-clamps.
pancho
« Reply #16 on: April 13, 2016, 04:23:47 AM » |
Refer to Mikes picture earlier in this post and do a search on it. He has found that it can be done with a 8 inch C-clamp,, I think he carries one in his bags.
« Reply #17 on: April 13, 2016, 04:24:34 AM » |
This is us replacing one in a parking lot in Alabama...  After that (one of us had to run off an buy clamps, we had to really scrounge for air to rebead the tire, no one had a board...) I made sure I had the needed stuff in my saddlebags... here's me testing an eight-inch clamp and a couple of boards at home...  Even if you could get the tire off the bead without the board (I couldn't) you might not want to use the tire again... the board prevents scary point-loads from the clamp(s)...  I haven't tested it yet, but this little hose screws into a spark plug hole and can supposedly spew out enough air fast enough to rebead a tire... it has a valve, it doesn't fill your tire with exhaust gas  ...  -Mike
« Last Edit: April 13, 2016, 04:28:59 AM by hubcapsc »
h13man
« Reply #18 on: April 14, 2016, 02:55:54 AM » |
You had a metal valve stem fail because you didn't have the keeper on it ? Yippers. Brand new with about 500 mi. on it after tires were changed. Mechanic didn't realize that a keeper was part of the tire change or neither did I. He was youngin' and I never experienced/seen this part before either. Heavier the object in centrifical force the more pressure on that object to fail. The previous owner neglected to reinstall them when he had the Metzlers installed.
sinner
HC SVNT DRACONES
Canberra OZ
« Reply #19 on: April 14, 2016, 03:33:34 AM » |
Thanks people! I have learned a lot. Just ordered Bridgeport Angled Aluminum Valve Stems. Cheers
« Reply #20 on: April 14, 2016, 03:41:27 AM » |
Thanks people! I have learned a lot. Just ordered Bridgeport Angled Aluminum Valve Stems. Cheers  I think those are super high quality... and I think you'll have to grind off the nub that the plastic supporter attached to in order to install them... that's why I went with the "regular" metal stems. There's nothing really wrong with grinding off the nub... its not like you'd want to go back to OEM valve stems... -Mike
« Reply #21 on: April 14, 2016, 03:45:02 AM » |
You had a metal valve stem fail because you didn't have the keeper on it ? Yippers. Brand new with about 500 mi. on it after tires were changed. Mechanic didn't realize that a keeper was part of the tire change or neither did I. He was youngin' and I never experienced/seen this part before either. Heavier the object in centrifical force the more pressure on that object to fail. The previous owner neglected to reinstall them when he had the Metzlers installed. There's "metal colored" OEM style valve stems, maybe they came on those later Valkyries with the polished wheels... I can't relate to one of these flying apart... ? ! ?  -Mike
« Reply #22 on: April 14, 2016, 08:26:58 AM » |
You had a metal valve stem fail because you didn't have the keeper on it ? Yippers. Brand new with about 500 mi. on it after tires were changed. Mechanic didn't realize that a keeper was part of the tire change or neither did I. He was youngin' and I never experienced/seen this part before either. Heavier the object in centrifical force the more pressure on that object to fail. The previous owner neglected to reinstall them when he had the Metzlers installed. There's "metal colored" OEM style valve stems, maybe they came on those later Valkyries with the polished wheels... I can't relate to one of these flying apart... ? ! ?  -Mike I don't know. My '01 standard with polished and clear coated wheels came with the OEM valves. There was part of them that were metal but not all the way thru. That's the only thing I can think he had. I don't see any way of the full metal ones moving at all.
« Reply #23 on: April 14, 2016, 09:33:23 PM » |
I broke my standoff on my ACE Tourer by pushing the tire gauge onto it, not believing that the tire only had 15psi in it, I thought it was the gauge not sealing and getting a proper reading.
I now use a screw on tire gauge. No more problem. But I have also removed the stand off, and either used a billet stem, or one of the metal 90'. I just off set it, so it doesn't hit the mounting point on the rim, no need to cut it off.
I wonder why we don't just use a straight stem, like the front tire, just get a low profile. No centrifugal pressure forcing the stem to bend. Only difficult to get to on the Tourer/IS model rear wheels.
« Last Edit: April 14, 2016, 09:49:25 PM by gordonv »
