April 01, 2026, 09:27:30 PM *
Author Topic: Clean ECT Mod?  (Read 3105 times)
Wayn-O
Orem, UT
« on: April 12, 2016, 06:13:21 PM »
So, I've got the IS ICM and IS carb springs installed on my standard.  Just put on the cobras 6 to 6 and have noticed a little drop in performance.  (Don't lecture me, I like the sound so they're staying on).
I've been considering the ECT mod for a while now and have read quite a few threads on it (there are many).  I have to ask, is it truly as badass as they say?
The only thing kind of holding me back is that I don't feel too stoked on cutting up the wiring for the mod.  I am playing with the idea of doing a clean ECT mod.  Hear me out and let me know if it's possible.
If I had an extra wire harness from another valk that had the red and blue connectors intact, cut them off, unplug them, and then reverse them so the cut wire ends are now together and solder them together, essentially making a male to female coupler that could simply plug into the existing red and blue connectors.  The CLEAN part is that you would do all of your splicing/installing-of-resistor/pot on the already cut/re-soldered coupler section of the wiring from the spare harness.  That way it would be 100% reversible; just simply unplug it and reconnect the original connectors.  No need to hack up your actual wiring.
What do you guys think?  Could it be done?  Am I missing something?
2000 GL1500C Valkyrie
2003 VT1100C Shadow Spirit
1998 VT1100C Shadow Spirit
1983 VF750C V45 Magna
sixlow
St. Augustine, Fl.
« Reply #1 on: April 12, 2016, 07:09:14 PM »
I think this is the next brilliant product to come from BonS. !!   cooldude
« Last Edit: April 12, 2016, 07:16:15 PM by sixlow » Logged
« Reply #2 on: April 12, 2016, 08:52:21 PM »
Yes. this is the kind of things I want to do. Plug-n-play.
But isn't this ECM mod one to be done on non-IS ECMs?
Wayn-O
Orem, UT
« Reply #3 on: April 12, 2016, 10:24:40 PM »
From what I've read Gordonv, if you use a smaller resistor it won't advance it the full 10 degrees.  That's why guys will put in a pot, so they have they have the ability to go part way or all the way.
http://www.valkyrieforum.com/bbs/index.php/topic,67250.0.html
big poppa pump
San Antonio, TX
« Reply #4 on: April 13, 2016, 06:20:26 AM »
I have an I/S ICM on both my tourers and I have also done the ECT mod on both of them, NO Pots. However I only used a 1k Ohm resistor instead of a 3.9k Ohm resistor for the mod.
I made my own harness for the mods on the bikes. Even though I had to cut the wiring on the bike at a couple of places, the mod is easily reversible since I used OEM style bullet connectors at all splices.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Wayn-O
Orem, UT
« Reply #5 on: April 13, 2016, 08:02:47 AM »
Big poppa I'd love to see some pics of your wiring. Your method sounds cheaper than my idea since I'd have to buy an entire harness just for two connectors.
With the 1K resistor does it still give it some good giddy-up? I'd be interested to hear your reasoning for deciding on the 1k resistor instead of something else like a 2k resistor. The original mod suggests a 3.9k and 2k would be roughly half of that. I don't want to go overboard in the advance and damage my engine so I'd love your thoughts.
big poppa pump
San Antonio, TX
« Reply #6 on: April 13, 2016, 08:43:14 AM »
Unfortunately no pics of wiring. The reason for the 1k resistor is the I/S ICM. The I/S ICM already gives a 2 degree advance, the 1k resistor gives roughly about 3-4 degree advance resulting in a total advance of 5-6 degrees. This would be the same as wiring in a 2k Ohm resistor with a Std ICM. I do have the I/S carb springs as well and both my bikes pull crazy fast.
VRCC#35870
VRCCDS#0266
turtle254
Livingston,Texas
« Reply #7 on: October 30, 2017, 04:39:53 PM »
I was thinking, why not just unplug the blue conn. and just put the pot across the pink and G/B wire before the ECT. Thus eliminating the ECT totally. Since this is what your doing anyway. Looks like a much simpler way to do all this.
turtle254
Livingston,Texas
« Reply #8 on: November 13, 2017, 02:54:46 PM »
  [/quote]
[/quote]
I guess no one wants to think about this simpler way on doing the Mod.
Just unplugging the blue conn, would give you 10 deg advance between 850rpm and 3500rpm with no Mod's at all !
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« Reply #9 on: November 13, 2017, 03:52:17 PM »
I am, you have pictures?
turtle254
Livingston,Texas
« Reply #10 on: November 13, 2017, 05:50:47 PM »
[/quote]
[/quote]
Edit ..
If the lead is open (or above ~ 20kohms), then the advance is disabled by the ICM.  So just unplugging the blue conn will disable the advance as will a total short to ground. Need some resistance to function.
across the plug.
Wayn-O
Orem, UT
« Reply #11 on: November 13, 2017, 06:40:45 PM »
I've also read that the full 10 degrees of advance is not wanted which is why people put in a potentiometer or a constant/fixed resistor of about 2K ohms (max resistance for 10 degree advance is something like 3.9K ohm).
turtle254
Livingston,Texas
« Reply #12 on: November 14, 2017, 11:24:05 AM »
[/quote]
Edit ..
across the plug.
[/quote]
Edit ..
The 850RPM and below "disable the advance" feature does not appear to be on 98 Std. This is good news so you don't have that jump on RPMs as you pass thur that range
Jersey
VRCC #37540
Southern Maryland
« Reply #13 on: November 14, 2017, 06:10:48 PM »
Might want to check this out.
http://www.valkyrieforum.com/bbs/index.php/topic,97969.0.html
The adjustable has been a nice feature.
Jersey
Jersey
VRCC #37540
Southern Maryland
« Reply #14 on: November 15, 2017, 01:17:31 PM »
From my experience the potentiometer has been very useful just for this reason.  I didn't like the way it was sounding at full resistance and was able to dial in exactly what worked for my bike and riding style.
Jersey
turtle254
Livingston,Texas
« Reply #15 on: November 15, 2017, 02:24:31 PM »
Edit ..
across the plug.
[/quote]
Edit ..
[/quote]
Edit ..
" Need some resistance to function" means fixed resistor or an adjustable Pot !
This is a way to do away with the ECT, which is what your doing in around about fashion with the original MOD. Much cleaner way and easily reversed by unpluging and repluging back in the ECT conn.
