February 11, 2026, 07:01:03 PM *
Author Topic: Gas tank O-ring  (Read 860 times)
flash2002
Montreal, Que
« on: April 14, 2016, 03:11:41 AM »
I bought a new o-ring for the gas tank valve I thought it looked small, well it is. The one I got seems to go around the filter but on the chart, they only show one. It seems to me there was a bigger o-ring when I took it apart last year, cant remember  uglystupid2 In the chart they only show one #6. Is there a bigger one that goes there and where is it on the chart or what number or size is it?
« Reply #1 on: April 14, 2016, 03:32:46 AM »
The threads on the valve hold it onto the tank, but the #6
O-ring is what keeps the gas from leaking out. It jambs down
over the stand-pipe and then the filter and then you screw
the valve back onto the tank... that's it I think...
pancho
Bonanza Arkansas
« Reply #2 on: April 14, 2016, 06:37:31 AM »
There is only one required in there Flash,  just don't remember off hand which side of the filter lip it goes on.
flash2002
Montreal, Que
« Reply #3 on: April 15, 2016, 02:05:41 AM »
That's weird because, when you look on the tank outlet side it as a grove as if there should be a o-ring in that place. I will try it the way it is with the small ring and see if it leaks or not.  Thanks guys
