February 11, 2026, 07:00:10 PM *
Author Topic: tappping or clicking noise  (Read 913 times)
NighthawkVTX
Gainesville, Fl
« on: April 15, 2016, 02:09:49 AM »
I took my Valk out for a 250 run last weekend. As I was coming home I noticed a tapping or clicking noise coming from the right side of the motor at low speeds.
When I got home I noticed what looked like a small oil stain around the right side middle cylinder head. I checked the oil level and it was full.
Any thoughts on what might have caused this to happen, and what the remedy should be?
If at first you don't succeed, then perhaps skydiving isn't for you
Blackduck
West Australia
« Reply #1 on: April 15, 2016, 03:19:18 AM »
Possibly a loose exhaust flange, check the nuts but don't get carried away with too much tension
Steel cowboy
Spring Hill, Fl.
« Reply #2 on: April 15, 2016, 03:46:49 AM »
The clicking sound could be the reed valves associated with your smog devices. It could be you need your valves adjusted too, I'd go with the smog devices first. Where was the oily stain at on the engine,  was it on top or under the head.
On top it might be a leaky intake manifold were you might need a retightening of the bolts due to your Orings leaking. If the Orings are bad an oily looking brown stain shows up around the manifold/head site. If it's under the head it could be the exhaust leaking needing new crush gaskets.
2001 black interstate
2003 Jupiter Orange wing
« Reply #3 on: April 15, 2016, 05:28:49 AM »
A picture of the oil/stain would as they say, save a thousand words
« Reply #4 on: April 15, 2016, 06:37:27 AM »
All of the above are good advice.
I have coasted up my driveway, heard a clicking, and discovered a big pebble stuck in my tire tread causing the clicking.  (Stock exhaust)
« Reply #5 on: April 15, 2016, 07:39:11 PM »
We are talking like 7 in or foot pounds, I forget. We are talking snug.
