January 29, 2026, 06:19:02 PM *
Author Topic: not shifting  (Read 1894 times)
srbarclay
Fort Smith, Ar.
« on: September 20, 2009, 11:40:42 AM »
I just replaced the shifter seal on my Valk.
I now only have first gear and neutral.
What did I do wrong.   uglystupid2
« Reply #1 on: September 20, 2009, 11:57:29 AM »
You probably did not replace the shifter pedal mechanism the same as it came off, and it now binds (or hits) against the exhaust or some other part of the motor when you try to shift up through the gears.
srbarclay
Fort Smith, Ar.
« Reply #2 on: September 20, 2009, 01:20:08 PM »
Ricky-D, you're correct.
I had the shifter angled just too high.
Simple adjustment.
Thanks for the advice.   cooldude
Earl in Pensacola
« Reply #3 on: September 20, 2009, 01:32:25 PM »
Quick question:  Were you able to R&R the seal by just removing the shifter etc??  A so called mechanic tried to tell me that the engine had to be loosened and moved, like the Goldwings !! ??  I've already bought the seal, but the leak is very small and slow.  It's the original and it has ONLY 209.7K on it.  I guess I better do it myself.
roboto65
Conroe,TX
« Reply #4 on: September 20, 2009, 01:36:33 PM »
No the engine does not have to be moved easy job!!!!
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
srbarclay
Fort Smith, Ar.
« Reply #5 on: September 20, 2009, 02:48:33 PM »
Earl
This is a 10 to 15 minute job, at most.
10mm nut at both shifter peg and shaft.
take off the shifter pef.
take off the shifter shaft. (use a long extension and a universal joint with your socket.
Gently pry off the shifter shaft.
Clean the seal area.
Scew in a short screw into the old seal. Then pull it out with pliers.
This will remove the old seal.
Oil the new seal and replace. tap it into place and put everything back on. cooldude cooldude
Daniel Meyer
The State of confusion.
« Reply #6 on: September 20, 2009, 07:21:32 PM »
http://lifeisaroad.com/valkshiftseal.html
CUAgain,
Daniel Meyer
