February 11, 2026, 07:00:23 PM *
Author Topic: How Many Dyna Beads?  (Read 924 times)
Steve K (IA)
Cedar Rapids, Iowa
« on: April 19, 2016, 10:49:33 AM »
I can't remember.  How many Dyna Beads go in the front and rear tires (MC tires)?
When I did this a while back, I think I put different amounts in, front and back.
I think maybe 2 oz in front and 3 oz in the rear.    ???
States I Have Ridden In
big poppa pump
San Antonio, TX
« Reply #1 on: April 19, 2016, 11:00:45 AM »
2 oz front and 3 oz rear.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
saddlesore
« Reply #2 on: April 19, 2016, 11:49:37 AM »
http://www.innovativebalancing.com/chart.htm#MotorcycleChart
DARE TO BE DIFFERENT
« Reply #3 on: April 19, 2016, 11:50:37 AM »
How easy is it to put beads in the front tire with tire on bike and 90 degree metal valve?
« Reply #4 on: April 19, 2016, 11:55:21 AM »
Its not hard. I have a little plastic bottle with a clear hose on it. Just takes a little patience. I think if one had something like a little engraver or something to vibrate the tire valve it would go really quick.
big poppa pump
San Antonio, TX
« Reply #5 on: April 19, 2016, 12:28:54 PM »
Very easy! If you have a compressor, it makes it even easier.
https://www.youtube.com/watch?v=-AaPu2IZy8c
VRCC#35870
VRCCDS#0266
N8171S
Marlboro, Mass
« Reply #6 on: April 19, 2016, 03:12:48 PM »
Those things are so small I lost count  when putting them in.  Probably in the thousands though.
pancho
Bonanza Arkansas
« Reply #7 on: April 19, 2016, 05:27:46 PM »
I finally got tired of coaxing them through the valve stem,, I just break a bead and pour them in. You do need to be careful of how you do it, so that even one bead does not get between the tire bead and rim.
Miker
St. Albert, AB.
« Reply #8 on: April 19, 2016, 07:19:24 PM »
Too funny! It was only a matter of time.
« Reply #9 on: April 20, 2016, 05:48:43 AM »
Steve K (IA)
Cedar Rapids, Iowa
« Reply #10 on: April 20, 2016, 10:27:06 AM »
 cooldude  Borrow the girlfriend/wife's vibrator.  Works good.  Hold against the hose or stem to excite the beads so they flow.
This is how I will do it next time.   https://www.youtube.com/watch?v=-AaPu2IZy8c
« Reply #11 on: April 20, 2016, 12:06:07 PM »
Vibrators work best!  2funny
My rides:
