February 11, 2026, 08:50:54 PM *
Author Topic: Alternator Cover Chrome  (Read 4213 times)
Gideon
Indianapolis, IN.
« on: April 19, 2016, 01:03:01 PM »
How can I remove the chrome that is beginning to wrinkle on my alternator cover (other just saying carefully). I would like to paint it rather than buy a new one.
« Reply #1 on: April 19, 2016, 02:51:12 PM »
Acetone maybe? I bought 2 new ones last year for less than 40 bucks. Think that source has dried up or caught on to what we were doing. Brake fluid might also eat the chrome away.
Gideon
Indianapolis, IN.
« Reply #2 on: April 19, 2016, 03:03:29 PM »
WOW that's cheap!
What was the source? Wink
« Reply #3 on: April 19, 2016, 05:54:38 PM »
WOW that's cheap!
Unfortunately they are long gone. A member from the Florida panhandle (who has since passed on) discovered they hadn't upped the price in Europe and many of us were able to get some before they did. RIP Xtracho  Smiley There are some members who have done as you are planning.
http://www.valkyrieforum.com/bbs/index.php/topic,67488.msg658165.html#msg658165
Here is one example.
« Reply #4 on: April 19, 2016, 06:13:01 PM »
I bought 6 of them  Shocked Shocked 2funny 2funny
« Reply #5 on: April 19, 2016, 06:57:35 PM »
Hoarder  Grin
Gideon
Indianapolis, IN.
« Reply #6 on: April 20, 2016, 06:57:49 AM »
If I ask real nice could get one of you to part with one?  Smiley
« Reply #7 on: April 20, 2016, 11:25:57 AM »
my 2nd one went on my brothers bike.
« Reply #8 on: April 20, 2016, 05:30:43 PM »
I have 2, one from each of my IS's. The latest one was so badly wrinkled, I just cracked it open in one spot, and spent 3 minutes peeling the chrome off the front. Has the broken tab, so will try the washer trick.
A lot of searching, and I found removing chrome from plastic models. I think it was oven cleaner. I bought the spray foam type, didn't work. Need liquid. Will try again.
Would be nice to leave the chrome on the Honda logo, but wasn't too selective, and I'm sure the dipping liquid wont be any better.
Gideon
Indianapolis, IN.
« Reply #9 on: April 21, 2016, 03:19:53 AM »
Thank you for the replies.
The local Honda Dealer is asking for $225 for a new one.
I wonder how it would be if I never bothered to put it back on.
The bike doesn't look bad without it.
Would it hurt anything?
« Reply #10 on: April 21, 2016, 04:28:03 AM »
There's one from a parted out bike on ebay, it looks dirty, but
unbubbled... and it still has the alternator attached to it... $99...
« Reply #11 on: April 21, 2016, 06:00:08 PM »
Mine is currently off, think of leaving it that way.
I think I'll paint the alt gloss black when I take it out for a cleaning and checking the brushes. Want to do that before any long rides.
vanagon40
Greenwood, IN
« Reply #12 on: April 21, 2016, 08:15:27 PM »
I'm thinking sand blasting. I have not tried it. I did get a small sandblaster for Christmas that I have not used. I have a couple of valve covers for my SilverWing and a chrome wrinkled Valkyrie alternator cover on my TODO list. The sandblaster is sitting next to my 45 Colt reloader (another Christmas present) that is also unused.
If you are on the southside, maybe we could check out my sandblaster sometime this summer.
« Last Edit: April 21, 2016, 08:16:59 PM by vanagon40 » Logged
Lyonardo
« Reply #13 on: April 21, 2016, 09:08:52 PM »
I got one last year on ebay for $22.
Keep checking, they show up there from time to time.
L
pancho
Bonanza Arkansas
« Reply #14 on: April 22, 2016, 06:31:14 AM »
I wouldn't try the sandblaster on the alternator cover vanagon,, it will destroy the item. Remember, it is made of plastic, the chrome plating, while very hard, is just a film on the plastic. The plastic is first blasted with copper dust to make it conductive, then plated with the chromium, it is probably best to peel  it off. I like gordonvs' idea of painting the alternator.
big poppa pump
San Antonio, TX
« Reply #15 on: April 22, 2016, 06:57:32 AM »
I disagree. I had my alternator cover sandblasted to remove the chrome and had it painted black.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
pancho
Bonanza Arkansas
« Reply #16 on: April 22, 2016, 07:44:55 AM »
Well, the sandblasters I have used would certainly destroy a piece of plastic, at least leave the surface in such a rough shape that you might as well put crinkle paint on it.
« Reply #17 on: April 22, 2016, 07:59:31 AM »
Gideon I sent you a PM. coolsmiley
Gideon
Indianapolis, IN.
« Reply #18 on: April 23, 2016, 07:36:37 AM »
Thanks for the replies. However, as you may have seen from my additional post, I now have developed an electrical problem. Some seem to think it’s my alternator. I hope not!  Sad
I need to resolve this issue before doing anything about the chrome cover.
jdp
« Reply #19 on: April 28, 2016, 09:49:32 PM »
I talked to a guy that said he copied one and made it out of fiberglass and painted it, I never saw it but sounds like a good idea, or maybe even plastic chrome it
Jruby38
Oxford Mass.
« Reply #20 on: April 29, 2016, 01:30:31 PM »
I don't think its a heat problem. Both my alt. cover and now the rear brake cover are wrinkled. The problem is cheep Honda plastic chrome.  These parts should have been made our of steel and plated like HD.
pancho
Bonanza Arkansas
« Reply #21 on: April 29, 2016, 02:38:26 PM »
It's really not "cheep Honda plastic chrome.", it is the same plastic all motorcycle and auto companies use to make exterior and trim pieces from these days. As far as the chrome,, it is real chromium plate,, the problem comes from the expansion characteristics of the chromium/nickel/copper layer vs. the plastic....  they are different and over many cycles can cause what we see..  industry wide problem and can be seen in many places.
« Last Edit: April 29, 2016, 02:41:16 PM by pancho » Logged
Gideon
Indianapolis, IN.
« Reply #22 on: May 03, 2016, 11:56:56 AM »
I peeled all the chrome off my Alternator Cover.
A good friend volunteered to paint it in "Fast" black to match my trike.
I will try to post a photo when it is finished.
I hope to have the alternator problem resolved soon.
98 VALK
« Reply #23 on: May 03, 2016, 07:58:58 PM »
GOOGLE  /  CHEAP CYCLE PARTS AND PUNCH IN HONDA VALKYRIE AND YOU CAN GET ANYTHING ON THAT VALK THAT YOU WANT. I WAS AT MC DONALD'S A COUPLE YEARS AGO AND SOMEONE HIT MY VALK WHILE IT WAS PARKED. I NEEDED SEVERAL ITEM'S AND THEY HAD EVERYTHING I NEEDED AND SHIPPED IT FAST. I JUST CHECKED THE ALTERNATOR COVER AND IT WAS $174.00
vanagon40
Greenwood, IN
« Reply #24 on: May 03, 2016, 09:03:38 PM »
If Cheap Cycle Parts want $174 for an alternator cover . . . .
"This is the most blatant case of false advertising since my suit against the movie The Neverending Story." Lionel Hutz, The Simpsons: New Kid on the Block [#4.8] (1992)
As an aside, ALL CAPS is not necessary and kind of annoying.
« Last Edit: May 03, 2016, 09:05:53 PM by vanagon40 » Logged
98 VALK
« Reply #25 on: May 03, 2016, 11:07:09 PM »
Vanagon40 you sound like your a very unhappy person and like to fault people. I'am 63 and have some fault's of my own and one of them is vision. Blind in one eye so using the cap's helps me. Very sorry if it bothered you. I rejoined the forum just recently for friendship & help on my valk. I'am coming off a motorcycle accident from being hit from behind at a traffic light. I have a 98 valk and bought about $2000.00 worth of parts from cheap cycle parts when i got in the wreck. So i can absolutely tell you that they are stand up people & delivered my parts promply & the price was great.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #26 on: May 04, 2016, 05:59:28 AM »
Procalibers price is $148.76. Still a lot of money.
So many roads, so little time
VRCC # 5258
indybobm
« Reply #27 on: May 04, 2016, 07:22:27 AM »
My experience with sandblaster cabinets is that dust and particles get on everything in the vicinity. I do not think I would want to reload ammunition next to one. Just a thought.
VRCC # 5258
« Reply #28 on: May 04, 2016, 08:37:17 PM »
I also was going to say something about the post too. All capitals is equivalent to shouting. It does also make it harder to read. Since we saw only 8 posts under your name, we reasoned that you are a new user, and was only trying to let you know of some on-line etiquette.
In your case, Sorry for bringing it up. No offense meant.
However, there is another person who when he posts, uses a larger font. I take it he does it also for ease of reading. I know on your computer, you can increase the words on your computer. I do this for my mother.
Press and hold down the "ctrl" key, and using a wheel mouse or a touch pad, scroll up. I'm not too sure how to do this on a regular keyboard, and would hope someone else can help, as I use a lap top for portability. This increases your font size, making it easier to read.
« Last Edit: May 04, 2016, 09:16:30 PM by gordonv » Logged
Cracker Jack
« Reply #29 on: May 05, 2016, 06:31:37 AM »
It's seems that a few people that just love to chastise others for using ALL CAPS. I, for one, am not offended or annoyed by people using all caps and don't have any trouble reading it. I can't discern any difference in the volume of all cap posts either. Necessary or not, I say type any way you like! cooldude
I do get a little annoyed with people that complain about ALL CAPS. tickedoff
« Last Edit: May 05, 2016, 06:36:07 AM by Cracker Jack » Logged
Roidfingers
Tuscaloosa, Alabama
« Reply #30 on: May 05, 2016, 07:58:31 AM »
You can increase the size of your screen by simply holding down the CNTRL key and hitting the + (plus) button on your keypad. To reduce hold and hit minus.
larue
Clermont,FL
« Reply #31 on: May 05, 2016, 08:08:19 AM »
From general board these are back on eBay more than 10, no affiliation here
http://www.ebay.com/itm/21333-MZ0-A00-Honda-Valkyrie-Alternator-Cover-/331848733018?fits=Make%3AHonda&hash=item4d43b9d15a:g:atUAAOSwrXdXK0Ro&vxp=mtr
Good luck
Gideon
Indianapolis, IN.
« Reply #32 on: May 05, 2016, 08:12:45 AM »
Cap's or No Cap's - Welcome back to this GREAT FORM!  cooldude
98 VALK
« Reply #33 on: May 05, 2016, 04:14:11 PM »
Very sorry for using caps guys. My vision is bad but i will not use them again and thanks to everyone for being so nice. I just came off a wreck two years ago and this is the first time i've been on my bike in over two years. Was hit from behind at a traffic light. It really shook me up so i put the bike away for several years over two to be exact. I was just to scared to ride i lost ny nerve i guess. I'am 63 this year and said to myself i was not going to give up riding. I got back on it and i'am as great of rider as i ever was and have one of the best machines that Honda ever made a 1998 Honda Valkyrie CT Tourer. Jade green / blk / & silver. I have never been in a wreck my whole life & it had to happen while i was on my motorcycle. Why couldn't it of happened while i was in the truck least i would of had a little protection. It felt good getting back on it today my wife was peeking out the front window as i took off into the street.
« Reply #34 on: May 05, 2016, 04:18:48 PM »
Congratulations !!! Don't worry about the caps. I'm sure your riding skills are just as good as they used to be. But don't get too overconfident, we are all getting older and our cat like reflexes aren't what they used to be. Happy Riding  cooldude
