February 11, 2026, 07:00:29 PM *
Author Topic: napa filter  (Read 1050 times)
slider
mulberry arkansas
« on: April 20, 2016, 03:48:13 PM »
has anyone used a napa oil filter on the valk??would anyone  recommend it or not ??
a proud navy veteran
« Reply #1 on: April 20, 2016, 05:48:13 PM »
Not personally, but in Shop Talk there is a post on compatible non-Honda replacements.
I had Purolator and Fram filters for my bike. Just used the last Puro (wally world doesn't have them anymore), and I had the Fram with my. A fellow GW biker, who also is a mechanic, said Frams are crap, don't use them. Haven't done the research yet, but don't need it till next year.
« Reply #2 on: April 20, 2016, 05:52:34 PM »
last I checked, their filters are made by WIX.
I use an oversized PureOne filter.
Gideon
Indianapolis, IN.
« Reply #3 on: April 21, 2016, 03:07:05 AM »
I have a NAPA Gold 1356 on my bike now.
It is made by WIX and about 3 ½” Long, same diameter as stock.
With it being longer than stock you can use all 4 qts. of oil, plus it is painted black.
I also use the Purolator PureOne PL14610, also 3 ½” Long.
I use my oil filter cover when I use the PureOne. It's painted a pretty yellow LOL.
2003Valkyrie
Wisconsin Rapids, Wisconsin
« Reply #4 on: April 21, 2016, 06:38:30 AM »
 cooldude  NAPA GOLD FILTER  as listed above !!!!  Been using for last 7 years now---matches the black bike  forget it is there doing its job.
Gideon
Indianapolis, IN.
« Reply #5 on: April 21, 2016, 06:53:31 AM »
This what NAPA advertises:
   "NAPA 1356 Gold Oil Filter Features Glass Enhanced Cellulose Media Traps 50% more contaminants  than traditional economy filter s; Has a 8-11 lb. By-Pass Relief Valve Setting; NAPA Gold Is The "Better" Filter Choice In The NAPA Family Of Lube Filter s When Using Synthetic or Synthetic Blended Motor Oils; Silicon Anti-Drain Back Valve Will Not Harden Or Become Brittle, Providing Greater Value And Protection Over Standard Nitrile Valves Used In Lesser Quality Economy Filter s; 21 Micron Attributes Beta Ratio : 2/20=6/20 Burst Pressure : 363 psi Flow Rate : 7 - 9 gpm Gasket I.D. (Inches) : 2.173" Gasket I.D. (mm) : 55 mm Media Type : Glass Enhanced Cellulose Oil Filter Gasket O.D. (Inches) : 2.475" Oil Filter Gasket O.D. (mm) : 63 mm Oil Filter Height (Inches) : 3.402" Oil Filter Height (mm) : 86 mm Oil Filter O.D. (Inches) : 2.685" Oil Filter O.D. (mm) : 68 mm Oil Filter compatible : SPin-On Lube Filter Oil Filter Thread Size (mm) : 20 x 1.50 mm Warranty NAPA Filter s are Covered by a Comprehensive Limited Product Warranty."
