March 27, 2026, 04:44:50 AM *
Author Topic: TBR Quick bags vs Rattlebars Bag Drop kit vs other  (Read 9743 times)
SgtBunny
"Don't be a Lemming!" - MCC
Kingwood, WV
« on: March 03, 2009, 10:59:23 PM »
I am wanting to make it easier for me to take my hard bags on and off.
Can you all give me some PRO/CON for different systems and you experiences with them.
thanks
VRCC #29625
'98 Tourer
JeffL
Maine
« Reply #1 on: March 04, 2009, 04:34:37 AM »
Definitely go with the Rattlebars!
I thought the Two Bros Valkyrie stuff was all discontinued.   ???
I don't know of any others.............
99 Valk
07 V-Strom 1000
Garland
#618
Hendersonville NC
« Reply #2 on: March 04, 2009, 04:58:10 AM »
I have had the TBR system for about nine years. I remember thinking it was grossly overpriced when I got it, as it basically consists of 8 stainless quick-release pins and a drill bit. I recently had to replace some of the pins, and they are quite expensive from marine supply shops, so maybe TBR wasn't so high after all. I am pretty sure they don't sell them anymore, but you could replicate the system easily enough. I don't have experience with Rattlebars system, but I have always been happy with everything I've purchased from Chet.
SgtBunny
Kingwood, WV
« Reply #3 on: March 04, 2009, 05:12:04 AM »
What size drill bit is needed and what are the specs on the pins?  Diameter, length etc.
VRCC #29625
'98 Tourer
John U.
Southern Delaware
« Reply #4 on: March 04, 2009, 09:39:33 AM »
I've been happy with Chet's prducts as well. The Bag Drop kit works well, but it too can be recreated. It's basically 4 pieces of stainless allthread, nuts and locknuts to replace the standard bolts. Seems unlikely that it would cost 50 some bucks (including shipping) to buy the pieces.
That said, I bought a second set (for a second bike) because it was too much trouble to recreate the kit.
Garland
#618
Hendersonville NC
« Reply #5 on: March 04, 2009, 05:07:14 PM »
The TBR system is eight 1/4" x 1" type "M" stainless quicklock pins.            http://www.bosunsupplies.com/products2.cfm?product=QRPinSuncor
Below are the installation instructions included with the kit:
Step 1: Remove the 4 bolts holding each saddle bag in place.
Step 2: Use 1/4 drill bit to drill out the threads from the bag mounting points. Use care to drill as straight a hole as possible.
Step 3: Set the bag back in posiition on the bike and insert each pin through the mounting hole while depressing the release button.
Step 4: After installing each pin it's a good idea to try to pull the pin out WITHOUT depressing the release button. This will insure a positive lock on each pin.
Step 5: Enjoy
I seem to remember the kit being about $200, but the pins are about $15 each-so about $120 all together.
SgtBunny
Kingwood, WV
« Reply #6 on: March 04, 2009, 11:12:32 PM »
I found another place for the pins at $10 ea: http://www.berkeleypoint.com/products/hardware/quick_lock_pin.html
I have read where some people notch their hardware in such a manner as:
http://www.valkyrieriders.com/shoptalk/tbrbag.htm
Has anyone done this and how well does it work.
« Last Edit: March 04, 2009, 11:18:54 PM by SgtBunny » Logged
VRCC #29625
'98 Tourer
