March 16, 2026, 07:58:37 AM
Florida Chapter
F6B rear suspension question
Topic: F6B rear suspension question (Read 1895 times)
OnaWingandaPrayer
April 29, 2016, 06:24:35 PM »
Do we have any F6b riders ? I am trying to learn/understand how the rear shock adjust/preload works. Do you push/pump , the pump knob or does it twist/screw-unscrew to adjust the shock?
No I dont have one
just been looking at things
Lucky Duck
Inverness, FL
Re: F6B rear suspension question
April 29, 2016, 06:48:19 PM »
You twist the adjuster knob from one detent to the next. There isn't any resistance on the knob as you turn it.
OnaWingandaPrayer
April 29, 2016, 07:08:14 PM »
Thanks Lucky Duck. Does it only change ride height ? I'd think it may change the spring rate/damping ?
Lucky Duck
Inverness, FL
April 29, 2016, 07:21:06 PM »
It changes the spring rate. I expect the ride height is changed too but probably not much. I tightened mine from what it was set at new and haven't touched it again. I only went a couple of detents and didn't notice a change in ride height.
